The ASUS ROG Swift PG27AQ gaming display is built for exceptional visuals in the professional gaming arena, and features a 4K/UHD resolution and IPS technology. Integrated NVIDIA G-SYNC technology synchronizes the display's refresh rate to the GPU to give you smooth visuals and lag-free gameplay.
ASUS-exclusive GameVisual technology
ASUS GameVisual Technology has six pre-set display modes to optimize visuals for different types of content. This unique feature can be easily accessed through a hotkey or the On Screen Display (OSD) settings menu. -
Super-narrow bezel design for seamless multi-display setups
The ROG Swift PG27AQ's slim profile and super-narrow 6mm bezel makes it perfect for almost seamless multi-display setups so your eyes move swiftly from one monitor to another. It can also be VESA wall-mounted - an even easier way to have a multi-display gaming setup. -
Flicker free technology
Flicker free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other damaging effects when you're embroiled in long, drawn-out gaming sessions. -
Ergonomic tilt, swivel, pivot, and height adjustable stand
The ROG Swift PG27AQ is specially designed for marathon gaming sessions. It has an ergonomically-designed stand with tilt swivel, pivot, and height adjustment so you can always find that ideal viewing position whether you're on the couch or sitting on your bed.
- ASUS ROG SWIFT PG27AQ - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 74 kWh
- Power Consumption (On mode)
- 50 W
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- 5-way joystick, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 24 Hz)
- Pixel Pitch
- 0.155 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey)
- Gaming
- Colour Support
- 1.074 billion colours (10-bit)
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.977 cm x 23.79 cm x 55.253 cm
- 7.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, CEL level 2, TUV Rheinland Low Blue Light Certification
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 74 kWh
- Diagonal Size
- 27"
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.155 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 30 - 60 Hz
- Horizontal Refresh Rate
- 50 - 133 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, Trace Free Technology, ASUS GamePlus, super narrow frame, Low Blue Light Mode, Flicker Free technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology
- Black
- 61.977 cm x 23.79 cm x 55.253 cm - with stand
- 7.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
Input
- 5-way joystick
- DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , HDMI , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
- Input Voltage
- 50 W
- Power Consumption (Typical)
- 90 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 61.977 cm - depth: 6.598 cm - height: 36.296 cm , With stand - width: 61.977 cm - depth: 23.79 cm - height: 55.253 cm - weight: 7.2 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
