Asus PCE-AC56 802.11ac Dual-band Wireless-AC1300 PCI-E Adapter
Quicklinx: 9SY9WS00 Mfr#: PCE-AC56
  • IEEE 802.11n
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Upgrade your PC to the next-generation of wireless
ASUS PCE-AC56 Dual-band Wireless-AC1300 PCI-E adapter is an 802.11ac Wi-Fi PCI Express adapter that upgrades your desktop PC to leading 802.11ac wireless that delivers wireless speeds up to 867 Mbps. Broadcom TurboQAM technology super-charges 2.4 GHz 802.11n performance from 300 Mbps to 400 Mbps with compatible devices. Plus, the external magnetized antenna base gives you more flexibility for adjusting antenna placement to get the best signal reception.
Instant Wi-Fi upgrade
With its PCI Express interface, PCE-AC56 plugs into any motherboard to give your desktop an instant 802.11ac Wi-Fi upgrade with access to speeds of up to 1.3 Gbps. With its external, magnetic antenna, attach it where you please and enjoy the strongest wireless performance.
Fastest Wi-Fi standard: 802.11ac
PCE-AC56 uses Broadcom's 5th generation Wi-Fi 802.11ac chipset to give you speeds of up to 867 Mbps through the 5 GHz band--3 times faster than 802.11n Wi-Fi. It maintains full backward compatibility with all previous Wi-Fi protocols for 2-way high performance transmission and seamless connections to your existing router.
Extend and strengthen your wireless connection
ASUS AiRadar intelligently strengthens wireless device connectivity using precise directional signal amplification for extended coverage, increased data throughput speed and enhanced stability. The added heatsink uses highly conductive aluminum to remove heat from the chipset for greater reliability for a reliable, stable connection.
  • The easy way to upgrade any desktop PC to super-fast next-generation 802.11ac Wi-Fi
    The ASUS PCE-AC56 is a 802.11ac Wi-Fi PCI Express adapter which upgrades your desktop from tangle-some Ethernet cables to carefree industry-leading 802.11ac at up to 867 Mbps. Broadcom TurboQAM technology super-charges 2.4 GHz 802.11n performance from 300 Mbps to 400 Mbps with compatible devices. Plus, the stylish external magnetized antenna base gives you more flexibility in adjusting antenna placement to get the best signal reception quality possible.
  • Fastest Wi-Fi standard: 802.11ac
    The PCE-AC56 uses Broadcom's Wi-Fi 802.11ac chipset to reach speeds of up to 867 Mbps through the 5 GHz band, which is three times faster than 802.11n Wi-Fi. At the same time, it maintains full backward compatibility with all previous Wi-Fi protocols, providing high performance two-way transmission while ensuring a smooth transition to 802.11ac and seamless interconnection with existing devices.
  • Extend and strengthen your wireless connection
    ASUS AiRadar intelligently strengthens wireless connectivity using 802.11ac beamforming technology, high power amplification, and exclusive ASUS RF fine-tuning. This ensures extended coverage, dynamic data speed increases, and enhanced stability.
  • No more dead zones with 150% better coverage
    A powerful signal-boosting high-gain design gives the PCE-AC56 improved signal transmission that extends Wi-Fi range and coverage by up to 150% compared to generic client devices. This extended coverage minimizes the possibility of dead spots at any location, offering fast and uninterrupted HD streaming and smooth multiplayer gaming throughout the home or office.
  • Instant Wi-Fi upgrade for desktops
    With its PCI Express interface, the PCE-AC56 plugs into any motherboard to give your desktop an instant 802.11ac Wi-Fi upgrade, with access to speeds of up to 1.3 Gbps. As it connects directly to the motherboard, there are no messy cables to clutter your computing environment, and no dedicated power supply is required.
  • Stylish aluminum heasink handles heat for extra stability
    The added heatsink uses highly-conductive aluminum to remove heat from the chipset, ensuring greater reliability for non-stop operation. Lower temperatures translate into a more stable device in all climate conditions, even during hot summers, and greater stability means more consistent connectivity and longer product lifespan. Plus, the heatsink has been crafted for a stylish look, once more showing ASUS always goes beyond the spec.
ASUS PCE-AC56 - network adapter - PCIe
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express
2.16 cm x 12.09 cm x 9.91 cm
105 g
802.11ac
Data Transfer Rate
1.3 Gbps
Performance
Maximum throughput (2.4 GHz): 400 Mbps , Maximum throughput (5 GHz): 867 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
Network adapter
Plug-in card
PCI Express
Wireless
Data Transfer Rate
1.3 Gbps
Performance
Line Coding Format
DBPSK, DQPSK, CCK, OFDM
Frequency Band
2.4 GHz, 5 GHz
ASUS AiRadar, magnetic aerial base, Broadcom TurboQAM technology
Aerial
Antenna
External detachable
Antenna Qty
2
3 x aerial - R-SMA
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
C-Tick, IC, FCC
Software Included
Drivers & Utilities
2.16 cm
12.09 cm
9.91 cm
105 g
Limited warranty - parts and labour - 2 years
10 - 90% (non-condensing)
