Asus PB60G Intel Core i5-8400T 16GB 256GB SSD 1TB Windows 10 Professional 64-bit
Quicklinx: F5R6WS00 Mfr#: PB60G-B5024ZD-OSS
Processor Type: Core i5
Operating System: Windows 10 Pro
Installed Memory: 16GB, 16GB
Hard Drive Capacity: 1.256TB
Storage Type: SSD
  • Core i5
  • IEEE 802.11n
Hurry, only 1 left in stock!
£824.37 ex VAT
£989.24 inc VAT
Solid reliability for your business
ASUS Mini PC PB60G is a compact workstation mini PC that features a stackable, modular design to deliver powerful customizability for professional usage. High-end NVIDIA® Quadro® P620 or Quadro® P1000 graphics combined with ISV certification makes Mini PC PB60G a perfect choice for 2D and 3D CAD applications. HDMI, DisplayPort and four mini DisplayPort outputs support up to seven displays for professionals who work with lots of visual information. ASUS Mini PC PB60G is also part of the ASUS Corporate Stable Model program, providing businesses with extensive support for long-term use and worry-free maintenance.
Workstation-grade performance, slim style
Powered by the 8th Gen Intel® Core™ Processors, ASUS Mini PC PB60G increases performance by up to 30% compared to previous generation processors for smoother handling of intensive computing tasks. Up to 32GB of fast DDR4 2400MHz memory boosts performance even further for improved multitasking, and a dual-storage design with one M.2 PCIe 3.0 x4 SSD and one 2.5-inch HDD provides the perfect mix of fast data transfers and high storage capacity.
Powerful NVIDIA® Quadro® graphics
ASUS Mini PC PB60G comes with a graphics module featuring an NVIDIA® Quadro® P620 or Quadro® P1000 graphics card to deliver fast, high-power performance when working with 2D or 3D models. Combined with support for up to seven 4K HDR displays that give you an expansive visual workspace to view your creations in stunning detail, Mini PC PB60G is the perfect tool for fields involving complex design tasks, such as media and entertainment, manufacturing, engineering and architecture.
Independent software vendor (ISV) certification
Independent software vendor (ISV) software is becoming an important factor to users in variety of industries. ASUS works in close partnership with ISV vendors, such as Adobe and Autodesk, to test and verify compatibility. This ensures ASUS Mini PC are reliable and highly effective for users in different fields.
High-speed data performance and large storage capacities
ASUS Mini PC PB60G supports Intel® Optane™, a smart and adaptable memory* technology that accelerates system performance and responsiveness, enabling up to 24X faster HDD access speeds, 19% faster daily computing performance, and 2.1X faster file searches. A high-capacity HDD, coupled with Intel® Optane™ memory, provides the optimal combination of large storage and incredibly fast data access.
Versatile, space-saving design
ASUS Mini PC PB60G has a stylish metal case that measures just 17.5 x 17.5 x 7cm, so it takes up very little room to help you maintain a clutter-free workspace. It can also be mounted easily to the back of any VESA-compatible display, making it perfect for a range of business applications — from a media server to a store kiosk.
Stackable, modular design for added functionality
ASUS Mini PC PB60G features a stackable, modular design with a choice of optional components, such as optical drive, that give you customized functionality to meet your specific needs.
  • Workstation-grade performance, slim style
    Powered by a robust processor, ASUS Mini PC PB60G increases performance for smoother handling of intensive computing tasks.
  • Powerful graphics
    ASUS Mini PC PB60G comes with a graphics module to deliver fast, high-power performance when working with 2D or 3D models. Combined with support for up to seven 4K HDR displays that give you an expansive visual workspace to view your creations in stunning detail, Mini PC PB60G is the perfect tool for fields involving complex design tasks, such as media and entertainment, manufacturing, engineering and architecture.
  • Versatile, space-saving design
    ASUS Mini PC PB60G has a stylish metal case that takes up very little room to help you maintain a clutter-free workspace. It can also be mounted easily to the back of any VESA-compatible display, making it perfect for a range of business applications - from a media server to a store kiosk.
  • Comprehensive connectivity
    ASUS Mini PC PB60G provides fast and convenient connectivity with two USB 3.1 Gen 2 and two USB 3.1 Gen 1 ports including one Type-C on the front panel, plus one USB 3.1 Gen 2 and two USB 2.0 ports on the rear panel.
  • Comprehensive protection, inside and out
    ASUS Mini PC PB60G is built with multiple safeguards and security features to protect your personal or business information. These include an industry-standard Kensington lock slot to prevent theft and an intrusion alert that warns you if Mini PC PB60G's chassis has been opened since last launch.
ASUS Mini PC PB60G B5024ZD - mini PC - Core i5 8400T 1.7 GHz - 16 GB - 1.256 TB
Workstation - mini PC
1 x Intel Core i5 (8th Gen) 8400T / 1.7 GHz (3 GHz) (6-core)
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB
Hard Drive (2nd)
1 x 1 TB - Serial ATA
Optical Storage
No optical drive
Graphics Controller
NVIDIA Quadro P620
Video Memory
2 GB GDDR5 SDRAM
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0
OS Provided
Windows 10 Pro
17.5 cm x 17.5 cm x 7.02 cm
1.59 kg
Environmental Standards
ENERGY STAR Qualified
Workstation
Product Form Factor
Mini PC
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B360
RAM
Installed Size
16 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total)
Hard Drive
SSD
1 x 256 GB
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
NVIDIA Quadro P620
Video Memory
2 GB GDDR5 SDRAM
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wi-Fi CERTIFIED
2 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 3 x USB 3.1 Gen 2 (2 front, 1 rear) , 2 x USB 3.1 Gen 1 (2 in front) (one of them is fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , 4 x Mini DisplayPort
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion alarm
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, C-Tick, BSMI, CB, CCC, FCC
Power adapter
Power Provided
120 Watt
Operating System / Software
OS Provided
Windows 10 Pro
ENERGY STAR Certified
17.5 cm
17.5 cm
7.02 cm
1.59 kg
Asus PB60G Intel Core i5-8400T 16GB 256GB SSD 1TB Windows 10 Professional 64-bit Bundle deal on Asus PB60G Intel Core i5-8400T 16GB 256GB SSD 1TB Windows 10 Professional 64-bit
£1,007.38
saving £8.33
£923.54
Storage Type: SSD
Processor Model: I5-8400T
Type: Workstation
Case Style: Ultra small form factor
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 750 - 1000
