ASUS Mini PC PB60 is a compact, versatile and powerful PC suited to a range of business applications, including office computing, conference rooms, retail store kiosks and digital signage. It delivers desktop-grade performance, while occupying minimal space. Its durable metal chassis and extensive testing exceeding industry standards ensure reliable, 24/7 operation, even in harsh environments. VESA-mount compatibility, comprehensive connectivity with eight USB ports and support for up to three 4K UHD displays provide flexibility for many usage scenarios, making Mini PC PB60 the perfect companion for your business.
Desktop-grade performance, slim style
Powered by an Intel processor, ASUS Mini PC PB60 delivers better performance to handle intensive computing tasks smoothly. -
Versatile, space-saving design
ASUS PC PB60 has a stylish and compact metal case, so it takes up very little room to help you maintain a clutter-free workspace. -
Stackable, modular design for added functionality
With stackable modules designed to fit perfectly, you can add just the functionality you need to Mini PC PB60 without sacrificing its compact size. -
Comprehensive connectivity
ASUS Mini PC PB60 provides fast and convenient connectivity with two USB 3.1 Gen2 and two USB 3.1 Gen1 ports including one Type-C on the front panel, plus one USB 3.1 Gen2 and two USB 2.0 ports on the rear panel. -
Tested for perfection
ASUS Mini PCs undergo rigorous noise, vibration, drop, and thermal shock tests to ensure they meet exacting ASUS standards and exceed industry requirements. Be confident that your ASUS mini PC can cope with extreme conditions, ranging from dry -40 °C temperatures, to humid and hot environments exceeding 60 °C for long periods of time. -
Comprehensive protection, inside and out
ASUS Mini PC PB60 is built with multiple safeguards and security features to protect your personal or business information. These include an industry-standard Kensington lock slot to prevent theft and an intrusion alert that warns you if Mini PC PB60's chassis has been opened since last launch.
- ASUS Mini PC PB60 B3062ZD - mini PC - Core i3 8100T - 8 GB - SSD 128 GB
- Personal computer - mini PC
- Processor
- Intel Core i3 (8th Gen) 8100T (Quad-Core)
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - M.2
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 630
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
- OS Provided
- Windows 10 Pro
- Black
- 17.5 cm x 17.5 cm x 3.42 cm
- 1.19 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini PC
- Black
Processor / Chipset
- CPU
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel B360
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
Hard Drive
- SSD - M.2
- Capacity
- 1 x 128 GB
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Wi-Fi CERTIFIED
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x M.2 Card
- 2 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 3 x USB 3.1 Gen 2 (2 front, 1 rear) , 2 x USB 3.1 Gen 1 (2 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear)
- Included Accessories
- VESA mounting kit, stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion alarm
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- UL, VCCI, C-Tick, BSMI, CB, CCC, FCC
- Power adapter
- Power Provided
- 90 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro
- ENERGY STAR Certified
- 17.5 cm
- 17.5 cm
- 3.42 cm
- 1.19 kg
