Asus PB60-B3062ZD Core i3-8100T 8GB 128GB SSD Windows 10 Pro
Quicklinx: DZRZWS00 Mfr#: PB60-B3062ZD-OSS
Processor Type: Core i3
Operating System: Windows 10 Pro
Installed Memory: 8GB
Hard Drive Capacity: 128GB
Storage Type: SSD
  • Core i3
£453.40 ex VAT
£544.08 inc VAT
ASUS Mini PC PB60 is a compact, versatile and powerful PC suited to a range of business applications, including office computing, conference rooms, retail store kiosks and digital signage. It delivers desktop-grade performance, while occupying minimal space. Its durable metal chassis and extensive testing exceeding industry standards ensure reliable, 24/7 operation, even in harsh environments. VESA-mount compatibility, comprehensive connectivity with eight USB ports and support for up to three 4K UHD displays provide flexibility for many usage scenarios, making Mini PC PB60 the perfect companion for your business.
  • Desktop-grade performance, slim style
    Powered by an Intel processor, ASUS Mini PC PB60 delivers better performance to handle intensive computing tasks smoothly.
  • Versatile, space-saving design
    ASUS PC PB60 has a stylish and compact metal case, so it takes up very little room to help you maintain a clutter-free workspace.
  • Stackable, modular design for added functionality
    With stackable modules designed to fit perfectly, you can add just the functionality you need to Mini PC PB60 without sacrificing its compact size.
  • Comprehensive connectivity
    ASUS Mini PC PB60 provides fast and convenient connectivity with two USB 3.1 Gen2 and two USB 3.1 Gen1 ports including one Type-C on the front panel, plus one USB 3.1 Gen2 and two USB 2.0 ports on the rear panel.
  • Tested for perfection
    ASUS Mini PCs undergo rigorous noise, vibration, drop, and thermal shock tests to ensure they meet exacting ASUS standards and exceed industry requirements. Be confident that your ASUS mini PC can cope with extreme conditions, ranging from dry -40 °C temperatures, to humid and hot environments exceeding 60 °C for long periods of time.
  • Comprehensive protection, inside and out
    ASUS Mini PC PB60 is built with multiple safeguards and security features to protect your personal or business information. These include an industry-standard Kensington lock slot to prevent theft and an intrusion alert that warns you if Mini PC PB60's chassis has been opened since last launch.
ASUS Mini PC PB60 B3062ZD - mini PC - Core i3 8100T - 8 GB - 128 GB
Personal computer - mini PC
1 x Intel Core i3 (8th Gen) 8100T (Quad-Core)
RAM
8 GB (installed) / 32 GB (max) DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 128 GB - M.2
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630
GigE, 802.11ac
OS Provided
Windows 10 Pro
17.5 cm x 17.5 cm x 3.42 cm
1.19 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Mini PC
Processor / Chipset
CPU
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel B360
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total)
Hard Drive
SSD - M.2
1 x 128 GB
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac
Wi-Fi CERTIFIED
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card
2 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 3 x USB 3.1 Gen 2 (2 front, 1 rear) , 2 x USB 3.1 Gen 1 (2 in front) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear)
VESA mounting kit, stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion alarm
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, C-Tick, BSMI, CB, CCC, FCC
Power adapter
Power Provided
90 Watt
Operating System / Software
OS Provided
Windows 10 Pro
ENERGY STAR Certified
17.5 cm
17.5 cm
3.42 cm
1.19 kg
Asus PB60-B3062ZD Core i3-8100T 8GB 128GB SSD Windows 10 Pro Bundle deal on Asus PB60-B3062ZD Core i3-8100T 8GB 128GB SSD Windows 10 Pro
£552.57
Storage Type: SSD
Processor Model: I3-8100T
Type: Personal computer
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 300 - 500
