ASUS Mini PC PB40 packs versatile desktop-computing power into stylish metal case that's just 17.5 cm square, and a mere 3.4 cm slim. The one-liter volume is no barrier to connectivity, with built-in Wi-Fi and USB 3.1 Gen 1 Type-C for simple, quick data transfers.
Versatile, space-saving design
ASUS Mini PC PB40's stylish metal case measures just 17.5x17.5x3.4 cm. This diminutive design takes up very little room, enabling a clutter-free workspace. Alternatively, Mini PC PB40 is easily mounted to the back of any VESA-compliant display, so it's perfect for diverse business applications - from media server to store kiosk. -
Loaded with connectivity
ASUS Mini PC PB40 packs in all the connectivity you'd expect from a modern desktop computer - and more besides. As well as USB 3.1 Gen 1 Type-A and Type-C, USB 2.0 and standard 3.5 mm audio jacks, Mini PC PB40 also boasts integrated Wi-Fi plus an antenna connector for improved wireless reception. -
Comprehensive protection, inside and out
ASUS Mini PC PB40 is built with multiple safeguards and security features to protect itself and your personal or business information. These include an industry-standard Kensington lock slot to prevent theft and an intrusion alert that warns you if Mini PC PB40's chassis has been opened since last launch. -
Tested for perfection
ASUS Mini PC PB40 has undergone rigorous noise, vibration, drop, and thermal shock tests to ensure it meets exacting ASUS standards and exceeds industry requirements. This offers the assurance that Mini PC PB40 can cope with extreme conditions - ranging from dry -40 °C temperatures to humid, hot environments exceeding 60 °C - for long periods of time.
- ASUS Mini PC PB40 BC056ZD - mini PC - Celeron N4100 - 4 GB - 32 GB
- Personal computer - mini PC
- Processor
- 1 x Intel Celeron N4100 (Quad-Core)
- RAM
- 4 GB (installed) / 8 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- 1 x SSD 32 GB - eMMC
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 600
- Networking
- GigE, Bluetooth, 802.11ac
- OS Provided
- Windows 10 Pro
- 17.5 cm x 17.5 cm x 3.42 cm
- 700 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Personal computer
- Product Form Factor
- Mini PC
- Black
Processor / Chipset
- CPU
- Intel Celeron N4100
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 4 GB / 8 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
Hard Drive
- SSD - eMMC
- Capacity
- 1 x 32 GB
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11ac
- Wi-Fi CERTIFIED
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 M.2 Card
- 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 5 x USB 3.1 Gen 1 (4 front, 1 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x USB 2.0 (1 rear) , 1 x serial
- Included Accessories
- VESA mounting kit, stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion alarm
- Security Slot Type
- Kensington security slot
- Mounting Interface
- UL, VCCI, C-Tick, BSMI, CB, CCC, FCC
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro
- ENERGY STAR Certified
- 17.5 cm
- 17.5 cm
- 3.42 cm
- 700 g
Bundle includes:
Microsoft Office Home & Business 2019 (Medialess, 1 PC, One Time Purchase) worth £192.05 | in stock |
£398.05
saving £8.33
saving £8.33
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£311.32
