Asus PB287Q 28" 3840x2160 1ms HDMI DisplayPort LED Monitor
Quicklinx: 9LDTWS00 Mfr#: PB287Q
Open your eyes to breathtaking levels of detail with the ASUS PB287Q True 4K ultra-high definition (4K UHD) monitor. The ASUS PB287Q features a 16:9 aspect ratio WLED display that delivers 4K UHD visuals, with resolution up to 3840 by 2160. With a pixel density of 157 pixels-per-inch (PPI), the PB287Q provides over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB287Q also delivers an impressive 1ms GTG fast response time and a 60 Hz refresh rate for ultra-smooth gameplay.
The ASUS PB287Q features extensive connectivity options that include DisplayPort 1.2 for true 4K UHD content support at refresh rates of up to 60 Hz, HDMI and a second HDMI port that supports MHL. You can also use the MHL with HDMI connection to view content from your mobile device on the PB287Q while simultaneously charging the mobile device.
  • Impeccable 4K ultra-high definition visuals
    Open your eyes to breathtaking levels of detail with the ASUS PB287Q True 4K ultra-high definition (4K UHD) monitor. The ASUS PB287Q features a 16:9 aspect ratio WLED display that delivers next-generation 4K UHD visuals, with resolution up to 3840 by 2160. With a pixel density of 157 pixels-per-inch (PPI), the PB287Q provides over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB287Q also delivers an impressive 1ms GTG fast response time and a 60 Hz refresh rate for ultra-smooth gameplay.
  • When 4K means seeing and doing much more
    With 300% more onscreen space than similar sized Full HD displays, the ASUS PB287Q gives you more space to spread out your various work windows for more productive multitasking. Capable of displaying 1.07 billion colors, the PB287Q delivers outstanding color reproduction and saturation thanks to its 330 cd/m2 brightness and a 100,000,000:1 ASUS Smart Contrast Ratio (ASCR).
  • Welcoming presumes and gamers alike to the 4K UHD club
    Real 10-bit colors means the ASUS PB287Q provides smooth color gradations for a more natural-looking transition between hues. The PB287Q also delivers an impressive 1 ms (gray-to-gray) fast response time and a 60 Hz refresh rate for fluid and responsive visuals needed to experience today's games to their fullest.
  • Everything you need, built right in
  • One display, two sources
    Build-in Picture-in-Picture (PiP) and Picture-by-Picture (PbP) functionality let you view content from two different sources simultaneously, with the ability to switch video between sources easily. PiP mode places the second input source window in one corner of the display, while PbP mode splits the screen down the middle.
  • ASUS-exclusive technologies for stunning image quality
    The PB287Q features the SplendidPlus Video Intelligence technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. SplendidPlus features two new modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, sRGB, and Night View modes. Low-blue Light and Flicker-free technologies also reduce the strain on your eyes after long-time usage.
  • Say hello to extraordinary comfort
    The PB287Q features a slim profile and an ergonomically-designed stand with tilt, swivel, pivot, and height adjustments so you can always find that ideal viewing position.
ASUS PB287Q - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.16 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Speakers
Integrated
Display Position Adjustments
66 cm x 22.006 cm x 41.4 cm
7.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, ERP, CEL level 1
3-year warranty
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
28"
Viewable Size
28"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
30 - 75 Hz
Horizontal Refresh Rate
24 - 99 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
Picture in picture, picture by picture, Zero Bright Dot, HDCP, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
66 cm x 22.006 cm x 41.4 cm - with stand
7.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Clamp
1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable
60 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 66 cm - depth: 6.355 cm - height: 38.067 cm
ENERGY STAR Certified
Limited warranty - 3 years
