Open your eyes to breathtaking levels of detail with the ASUS PB279Q 4K UHD monitor. The PB279Q features a 16:9 aspect ratio WLED display that delivers 3840 x 2160 resolution 4K UHD visuals. With a pixel density of 163 pixels-per-inch (PPI), the PB279Q has over 8 million pixels, four times the pixel density of standard Full HD displays for astonishingly detailed visuals - allowing you to experience more onscreen real estate and stunning image clarity that have to be seen to be believed. The PB279Q features In-Plane Switching technology for 178-degree wide-viewing angles on both horizontal and vertical planes, as well as 100% sRGB wide color gamut for consistent color reproduction and true-to-life visuals.
When 4K means seeing and doing much more
4K UHD visuals means the ASUS PB279Q lets you enjoy more desktop space than a similarly-sized Full HD screen on which to spread out your various windows. Capable of displaying 1.07 billion colors, the PB279Q delivers outstanding color reproduction and saturation; along with a brightness of 300cd/m² and a 100,000,000:1 ASUS Smart Contrast Ratio (ASCR). -
Impressive 100% sRGB, 10-bit colors, and 5 ms response time
A 100% sRGB wide color gamut allows the ASUS PB279Q to consistently replicate colors in a way not seen on standard monitors; while 10-bit colors means the PB279Q provides smooth color gradations for a more natural-looking transition between hues. The PB279Q also delivers an impressive 5 ms fast response time and a 60 Hz refresh rate for the fluid and responsive visuals needed to experience today's games at their fullest. -
Running 4K UHD at 60 Hz
The ASUS PB279Q features extensive connectivity options that include DisplayPort 1.2 and Mini DisplayPort for 4K UHD content support at refresh rates of up to 60 Hz . There's also four HDMI 1.4 / MHL ports which you can use to view content from your mobile device on the PB279Q while simultaneously charging the mobile device. -
View four input sources on one display simultaneously
Built-in Picture-in-Picture (PiP) and Picture-by-Picture (PbP) functionality let you view content from up to four different 4K/UHD sources simultaneously, with the ability to switch between them, including audio, easily. PiP mode places the second input source window in one corner of the display, while PbP mode allows you to set up the input source windows in four different ways, and can support four 4K/UHD windows at the same time. -
ASUS-exclusive technologies for stunning image quality
We've raised the bar by incorporating proprietary technologies into the ASUS PB279Q to give you a truly vivid visual experience. The PB279Q features the SplendidPlus Video Intelligence Technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. -
Your viewing experience matters
The PB279Q features a slim profile and an ergonomically designed stand with tilt, swivel, pivot, and height adjustments so you can always find that ideal viewing position.
- ASUS PB279Q - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 72.7 kWh
- Power Consumption (On mode)
- 49.8 W
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
- Pixel Pitch
- 0.15525 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Black
- 62.49 cm x 22 cm x 40.77 cm
- 10 kg
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 72.7 kWh
- Diagonal Size
- 27"
- Panel Type
- AHVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.15525 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Mobile High-Definition Link (MHL)
- Black
- 10 kg
Audio
- Speakers - stereo - integrated
- MHL / HDMI , DisplayPort , Mini DisplayPort
Mechanical
- Cables Included
- 1 x audio cable , 1 x HDMI cable , 1 x DisplayPort cable
- Power Supply
- Internal
- 49.8 W
- Power Consumption (Typical)
- 90 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years
