The PB278QR offers a highly ergonomic and smart design that complies with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment. Premium 16:9 wide-format PB278QR LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. HDMI, DisplayPort, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
Precision to the finest detail
Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! Premium 16:9 wide-format PB278QR LED displays with 178° wide viewing angle panel for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true "what you imagine is what you create" power. HDMI, DisplayPort, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop. -
See better and wider
The PB278QR WQHD monitor provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals - equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays. The screen's 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PB278QR, power and energy savings are no longer compromised, while better visuals are assured. -
Made for work and play
The ASUS PB278QR provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27" full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB278QR is undoubtedly your best choice for work and play. -
Native WQHD content support
The PB278QR features a host of connectivity options that include HDMI, DisplayPort, and dual-link DVI for native WQHD, plus D-sub for full HD 1080p content transmission. The HDMI port also supports MHL which allows you to use the MHL with HDMI connection to view content from your mobile device on the PB278QR while simultaneously charging the mobile device. Twin built-in 3W speakers provide quality audio for a completely immersive home theater experience. -
QuickFit virtual scale for true what you see is what you get
ASUS includes its exclusive QuickFit Virtual Scale feature with the PB278QR, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. -
Designed with you in mind
- ASUS PB278QR - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 53 kWh
- Power Consumption (On mode)
- 36 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.3 cm x 21.8 cm x 55.23 cm
- 7.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, PSE Mark, GOST-R, J-MOSS, ErP Ready
- Display Type
- Energy Class
- Class B
- 53 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, input select, colour temperature
- Picture in picture, picture by picture, Zero Bright Dot, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
- Black
- 64.3 cm x 21.8 cm x 55.23 cm - with stand
- 7.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2.5 Watt
- HDMI , DisplayPort , Audio line-in , Headphones , DVI-D (dual link) , VGA
Mechanical
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x audio cable , 1 x DVI cable , 1 x VGA cable
- Input Voltage
- 36 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 64.3 cm - depth: 6.96 cm - height: 38.62 cm
Sustainability Information
- ENERGY STAR Certified
