Product
Asus PB277Q 27" 2560x1440 1MS HDMI, DVI-D VGA Monitor
Quicklinx: CW2GWS00 Mfr#: PB277Q
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
More than 50 in stock
£231.48 ex VAT
£277.77 inc VAT
The PB277Q WQHD monitor provides 109 PPI, resulting in high-quality visuals. It allows users to view greater image detail and do more with a larger onscreen footprint. With this WQHD display, you enjoy significantly more desktop space to spread out your windows and palettes. It is also sharper than a generic Full HD display, delivering ultra-smooth visuals thanks to minimal response time. This ensures you get lag-free experiences in movies and gaming. The ASUS PB277Q is undoubtedly your advanced choice for work and play.
  • True-to-life visuals
    The PB277Q WQHD monitor provides 109 PPI, resulting in high-quality 2560 x 1440 visuals - equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
  • Made for work and play
    With this WQHD display, you enjoy significantly more desktop space than a Full HD screen to spread out your windows and palettes. It is also sharper than a generic full HD display, delivering ultra-smooth visuals thanks to minimal response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB277Q is undoubtedly your advanced choice for work and play.
  • Game fast and smooth
    Short-time response eliminates tracers by controlling voltage levels when driving liquid crystals thus resulting in fluid and clear video playback without smearing or ghosting. Together with the refresh rate 75 Hz to eliminate tracing and ensure crisp and clear video playback.
  • Extensive connectivity
    The PB277Q features a host of connectivity options that include HDMI, DisplayPort, and dual link DVI for native WQHD, plus D-sub for Full HD 1080p content transmission.
  • QuickFit Virtual Scale for true what you see is what you get
    ASUS includes its exclusive QuickFit Virtual Scale feature with the PB277Q, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
  • ASUS exclusive technologies for stunning image quality
    The bar has been raised by incorporating some of the proprietary technologies into the ASUS PB277Q to give you a truly vivid visual experience. The PB277Q features the advanced SplendidPlus Video Intelligence technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. SplendidPlus features two different modes - reading and darkroom - in addition to the scenery, standard, theater, sRGB, and night view modes. Low Blue Light and Flicker Free technologies also reduce the strain on your eyes after long-time usage.
  • ASUS eye care technology
    ASUS eye care monitor provides eye care features - Flicker Free and Low Blue Light technology with 4 different levels that prevent your eyes from fatigue, strain that caused by screen flicker, hazard blue light and various light sources from office environment.
  • Designed with you in mind
    The PB277Q offers a highly ergonomic and smart design that comes with tilt, pivot, swivel, and height adjustments to ensure an always comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment.
ASUS PB277Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
72 kWh
Power Consumption (On mode)
49 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD WQHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours (8-bit)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
62.5 cm x 21.8 cm x 42.8 cm
7.3 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, PSE Mark, J-MOSS, ErP Ready, TCO Displays 6.0, RCM, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class C
72 kWh
49 W
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Input select, colour temperature
Picture in picture, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
62.5 cm x 21.8 cm x 42.8 cm - with stand
7.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (dual link) , DisplayPort , HDMI , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
120 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
38.7 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 62.5 cm - depth: 21.8 cm - height: 42.8 cm - weight: 7.3 kg , Without stand - width: 62.5 cm - depth: 6.3 cm - height: 36.8 cm
Shipping Width
75.3 cm
Shipping Depth
22.4 cm
Shipping Height
45.2 cm
Shipping Weight
10.5 kg
ENERGY STAR Certified
Asus PB277Q 27 Bundle deal on Asus PB277Q 27" 2560x1440 1MS HDMI, DVI-D VGA Monitor
£331.24
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 150 - 300
