The PB277Q WQHD monitor provides 109 PPI, resulting in high-quality visuals. It allows users to view greater image detail and do more with a larger onscreen footprint. With this WQHD display, you enjoy significantly more desktop space to spread out your windows and palettes. It is also sharper than a generic Full HD display, delivering ultra-smooth visuals thanks to minimal response time. This ensures you get lag-free experiences in movies and gaming. The ASUS PB277Q is undoubtedly your advanced choice for work and play.
True-to-life visuals
The PB277Q WQHD monitor provides 109 PPI, resulting in high-quality 2560 x 1440 visuals - equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays. -
Made for work and play
With this WQHD display, you enjoy significantly more desktop space than a Full HD screen to spread out your windows and palettes. It is also sharper than a generic full HD display, delivering ultra-smooth visuals thanks to minimal response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB277Q is undoubtedly your advanced choice for work and play. -
Game fast and smooth
Short-time response eliminates tracers by controlling voltage levels when driving liquid crystals thus resulting in fluid and clear video playback without smearing or ghosting. Together with the refresh rate 75 Hz to eliminate tracing and ensure crisp and clear video playback. -
Extensive connectivity
The PB277Q features a host of connectivity options that include HDMI, DisplayPort, and dual link DVI for native WQHD, plus D-sub for Full HD 1080p content transmission. -
QuickFit Virtual Scale for true what you see is what you get
ASUS includes its exclusive QuickFit Virtual Scale feature with the PB277Q, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. -
ASUS exclusive technologies for stunning image quality
The bar has been raised by incorporating some of the proprietary technologies into the ASUS PB277Q to give you a truly vivid visual experience. The PB277Q features the advanced SplendidPlus Video Intelligence technology that optimizes videos and images by enhancing color brightness, contrast, and sharpness. SplendidPlus features two different modes - reading and darkroom - in addition to the scenery, standard, theater, sRGB, and night view modes. Low Blue Light and Flicker Free technologies also reduce the strain on your eyes after long-time usage. -
ASUS eye care technology
ASUS eye care monitor provides eye care features - Flicker Free and Low Blue Light technology with 4 different levels that prevent your eyes from fatigue, strain that caused by screen flicker, hazard blue light and various light sources from office environment. -
Designed with you in mind
The PB277Q offers a highly ergonomic and smart design that comes with tilt, pivot, swivel, and height adjustments to ensure an always comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment.
- ASUS PB277Q - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class C
- Energy Consumption per Year
- 72 kWh
- Power Consumption (On mode)
- 49 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- QHD WQHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours (8-bit)
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 62.5 cm x 21.8 cm x 42.8 cm
- 7.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, PSE Mark, J-MOSS, ErP Ready, RCM, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification
- Display Type
- Energy Class
- Class C
- 72 kWh
- 49 W
- Diagonal Size
- 27"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Input select, colour temperature
- Picture in picture, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, Smart View Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
- Black
- 62.5 cm x 21.8 cm x 42.8 cm - with stand
- 7.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DVI-D (dual link) , DisplayPort , HDMI , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 38.7 Watt
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 62.5 cm - depth: 21.8 cm - height: 42.8 cm - weight: 7.3 kg , Without stand - width: 62.5 cm - depth: 6.3 cm - height: 36.8 cm
- Shipping Width
- 75.3 cm
- Shipping Depth
- 22.4 cm
- Shipping Height
- 45.2 cm
- Shipping Weight
- 10.5 kg
- ENERGY STAR Certified
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£336.44
