Asus PB248Q 24" 1920x1200 6ms VGA DVI HDMI DisplayPort IPS LED Monitor
Quicklinx: 9TR1WS00 Mfr#: PB248Q
The ASUS PB248Q features a 16:10 aspect ratio, A+ IPS LED-backlit panel for sRGB and NTSC color reproduction; additionally, along with a 178° wide viewing angle, it ensures quality visuals and minimal onscreen color shift from almost any viewing position. ASUS PB248Q also delivers ultra-smooth visuals thanks to a quick response time - ensuring users have a lag-free viewing experience when it comes to watching movies or playing games. Games played under the PB248Q are more vivid - as all details can be seen and true color can be shown with the PB248Q. The ergonomically-designed PB248Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
  • Optimal HD A+ IPS panel
  • ASUS Smart Contrast Ratio
    With ASUS Smart Contrast Ratio the ASUS PB248Q enhances display contrast and sharpness - by adjusting the luminance of the backlight to achieve the darkness black and brightest white - delivering lifelike visuals.
  • Customized color adjustment
    Customized hue and saturation control with 6 color adjustment allows user to adjust six colors independently without affecting other colors.
  • Ultra-smooth visuals
  • Splendid video intelligence technology
    ASUS Splendid Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user's current task, thereafter adjusting the display's parameters according to ensure color accuracy and image fidelity. Six preset modes can be selected via a designated hotkey.
  • Extensive connectivity and built-in stereo speaker for multimedia enjoyment
    PB248Q comes with rich connectivity including HDMI, DisplayPort, DVI, D-sub and Earphone jack. It is also equipped with four USB 3.0 ports so that users could easily connect PB248Q to many peripherals, such as USB drives, keyboard, mouse, digital camera. Simultaneously connect to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with built-in stereo speakers. It has also built-in hidden stereo speakers for multimedia enjoyment.
  • Intuitive 5 way navigation key
    The PB248Q has a 5-way navigation key that acts as a joystick that gives access to the QuickFit Virtual Scale function along with all OSD functions and settings.
  • Customizable OSD shortcuts
    The PB248Q features customizable OSD shortcuts through two designated hotkeys for quick access to most frequently used OSD functions.
  • QuickFit virtual scale
    The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activate via a hotkey on monitor and used as a guide to accurately view and edit photos.
  • Versatile comfort with ergonomic design
ASUS PB248Q - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
29.1 kWh
Power Consumption (On mode)
19.9 W
Stereo speakers, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB, 72% NTSC
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
55.72 cm x 23.5 cm x 41.63 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, NOM, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, GOST-R, J-MOSS, ErP Ready
Display Type
Energy Class
Class A+
29.1 kWh
Diagonal Size
24.1"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB, 72% NTSC
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Gamma correction, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 5-way Navigation Key, customisable OSD buttons, 72% NTSC colour gamut
55.72 cm x 23.5 cm x 41.63 cm - with stand
6.6 kg
Audio
Speakers - stereo - integrated
VGA , DVI-D , Audio line-in , DisplayPort , HDMI , Headphones , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x USB cable
Input Voltage
19.9 W
Power Consumption (Typical)
65 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.1 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 55.72 cm - depth: 6.2 cm - height: 36.28 cm
Sustainability Information
ENERGY STAR Certified
