The ergonomically-designed PA238Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
80,000,000:1 ASUS smart contrast ratio
Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. -
Full HD with HDMI
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. -
178° wide viewing angle
PB238Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it. -
Extensive connectivity and built-in stereo speaker for multimedia enjoyment
PB238Q comes with rich connectivity including HDMI, DisplayPort, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc Simultaneously connect to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with built-in stereo speakers. -
QuickFit virtual scale
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
- ASUS PB238Q - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class B
- Energy Consumption per Year
- 25 kWh
- Power Consumption (On mode)
- 24 W
- USB 2.0 hub
- Panel Type
- IPS
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 54.88 cm x 20.1 cm x 41.42 cm
- 5.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, PSE Mark, GOST-R, J-MOSS, ERP
- Display Type
- Energy Class
- Class B
- 25 kWh
- Diagonal Size
- 23"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, input select, colour temperature
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
- Black
- 54.88 cm x 20.1 cm x 41.42 cm - with stand
- 5.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , Audio line-in , DisplayPort , HDMI , 4 x USB 2.0 downstream , USB 2.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x USB cable - USB Type A to B
- Power Supply
- Internal
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 33 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 54.88 cm - depth: 5.76 cm - height: 32.37 cm
Sustainability Information
- ENERGY STAR Certified
