Asus PB238Q 23" 1920x1080 6ms VGA DVI HDMI DisplayPort IPS LED Monitor
Quicklinx: 9TR5WS00 Mfr#: PB238Q
The ergonomically-designed PA238Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
  • 80,000,000:1 ASUS smart contrast ratio
    Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
  • Full HD with HDMI
    Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port.
  • 178° wide viewing angle
    PB238Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it.
  • Extensive connectivity and built-in stereo speaker for multimedia enjoyment
    PB238Q comes with rich connectivity including HDMI, DisplayPort, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc Simultaneously connect to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with built-in stereo speakers.
  • QuickFit virtual scale
    The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
ASUS PB238Q - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
24 W
USB 2.0 hub
Panel Type
IPS
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
54.88 cm x 20.1 cm x 41.42 cm
5.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, PSE Mark, GOST-R, J-MOSS, ERP
Display Type
Energy Class
Class B
25 kWh
Diagonal Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
54.88 cm x 20.1 cm x 41.42 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , DisplayPort , HDMI , 4 x USB 2.0 downstream , USB 2.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x USB cable - USB Type A to B
Power Supply
Internal
Input Voltage
24 W
Power Consumption (Typical)
33 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 54.88 cm - depth: 5.76 cm - height: 32.37 cm
Sustainability Information
ENERGY STAR Certified
