ProArt PA32UC brings onscreen realism to another level. Its Ultra HD Premium-certified 4K IPS panel produces up to 1000 nits of brightness and delivers Rec. 2020, Adobe RGB, DCI-P3 and sRGB color space, providing a lifelike HDR experience that is ideal for advanced video editing. ProArt PA32UC is factory pre-calibrated and it features ProArt calibration technology to ensure color accuracy with a ?E value below 2. Certified for Windows and Mac OS, it's ideal for graphic designers, photographers and professional content creators.
- ASUS ProArt PA32UC-K - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class B
- Energy Consumption per Year
- 67 kWh
- Power Consumption (On mode)
- 46 W
- 5-way joystick, USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 65 Hz, Thunderbolt 3: 60 Hz)
- Pixel Pitch
- 0.1845 mm
- Brightness
- 1000 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB, 85% Rec 2020, 95% DCI-P3
- Input Connectors
- 4xHDMI, DisplayPort, Thunderbolt 3
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Grey
- 72.7 cm x 22.9 cm x 60 cm
- 11.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, ICES, J-MOSS, E-Standby, UkrSEPRO, KC, ERP, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 67 kWh
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1845 mm
- Brightness
- 1000 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 29 - 65 Hz
- Horizontal Refresh Rate
- 109 - 142 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture in picture, picture by picture, ErgoDesign, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, 14-bit lookup table, Flicker Free technology, ASUS EyeCare Technology, 6-axis colour adjustment, ASUS ProArt Calibration technology, Bluelight Filter, Hardware Calibration Ready, USB-C power delivery up to 60 W
- Grey
- 72.7 cm x 22.9 cm x 60 cm - with stand
- 11.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
Input
- 5-way joystick
- Thunderbolt 3 / USB-C , Thunderbolt 3 / USB-C output , 4 x HDMI , DisplayPort , Headphones , USB 3.0 downstream with Power Delivery , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 120
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x Thunderbolt 3 / USB-C cable
- Input Voltage
- 46 W
- Power Consumption (Typical)
- 56.84 Watt
- 0 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 72.7 cm - depth: 6.9 cm - height: 42.6 cm - weight: 7.8 kg
- Shipping Width
- 91.3 cm
- Shipping Depth
- 52.1 cm
- Shipping Height
- 36.5 cm
- Shipping Weight
- 16.7 kg
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
- 0 °C
- 40 °C
