Asus PA329Q 32" 3480x2160 HDMI LED Monitor
Quicklinx: CW2CWS00 Mfr#: PA329Q
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort
£1,111.11 ex VAT
£1,333.33 inc VAT
The ASUS ProArt PA329Q 4K UHD professional monitor delivers accurate and brilliant color reproduction and is designed for graphics professionals. PA329Q is ideal for high-end video editing, thanks to a wide color gamut of 100% Rec. 709 and 99.5% Adobe RGB for exceptional color fidelity, and it has the ability to display multiple 4K UHD video inputs at up to 60Hz. In addition, ASUS ProArt Calibration Technology offers advanced color tuning and uniformity compensation to ensure outstanding color accuracy, making PA329 the perfect monitor for photographers, colorists, graphic designers, and film editors.
ProArt PA329Q has a wide color gamut so you have an entire spectrum of colors to play with. The use of 3M Quantum Dot Enhancement Film (QDEF) provides a wide color range, allowing PA329Q to support 100% Rec. 709, 100% sRGB, 99.5% Adobe RGB, 90% DCI-P3, and Rec. 2020 color spaces for video editing and production. On top of that, IPS display technology gives you wide viewing angles so there's no color shift, even when you're viewing PA329Q from extreme positions.
Revel in pure, expressive hues thanks to accurate, true-to-life color reproduction. Each ProArt PA329Q monitor is factory pre-calibrated to guarantee industry-leading color accuracy (?E < 2), so your images are accurately reproduced onscreen, allowing you to see exactly how your work is going to look when it's finished. PA329Q also comes with 95% uniformity compensation to guard against brightness and chroma (color) fluctuations on different parts of the screen.
ASUS PA329Q - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
67 kWh
Power Consumption (On mode)
46 W
9-in-1 card reader, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 60 Hz)
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
4xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
73.5 cm x 24 cm x 61.5 cm
12.5 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, TUV Rheinland Low Blue Light Certification, CEL level 0, CU, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
67 kWh
46 W
Diagonal Size
32"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Pixel Per Inch
138
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
30 - 135 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Picture in picture, picture by picture, ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 100% sRGB colour gamut, 14-bit lookup table, ASUS VividPixel Technology, Flicker Free technology, slim bezel design, 6-axis colour adjustment, 99.5% Adobe RGB colour gamut, Factory Calibration Report, 100% Rec 709 colour gamut, 90% DCI-P3, ASUS ProArt Calibration technology, 3M Quantum Dot Enhancement Film
73.5 cm x 24 cm x 61.5 cm - with stand
12.5 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
4 x HDMI , Mini DisplayPort , DisplayPort , Headphones , 5 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), quick release mechanism
Cable tie
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x USB cable
Security Slot Type
Kensington security slot
47.49 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Microsoft Windows 7 / 8.1 / 10
Shipping Width
84.7 cm
Shipping Depth
55.2 cm
Shipping Height
35 cm
Shipping Weight
15.7 kg
ENERGY STAR Certified
Asus PA329Q 32 Bundle deal on Asus PA329Q 32" 3480x2160 HDMI LED Monitor
£1,210.87
Diagonal Size: 32in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Asus
Price Range Ex VAT: 1000 - 1500
