Asus PA328Q 31.5" Wide IPS LED Monitor 4K
Quicklinx: B4NRWS00 Mfr#: PA328Q
Open your eyes to breathtaking levels of detail with the ASUS PA328Q true 4K ultra-high definition monitor. It features a super-narrow bezel design and a 16:9 aspect, 32-inch panel to give you stunning visuals in resolutions of up to 3840 x 2160. PA328Q gives you 300% more onscreen space to work with than similarly-sized Full HD displays, allowing you to spread out your various work windows for more productive multitasking. Revel in pure, expressive hues thanks to accurate, true-to-life color reproduction. Each PA328Q monitor is factory pre-calibrated to guarantee industry-leading color accuracy, so your images are accurately reproduced onscreen, allowing you to see exactly how your work is going to look when it's finished. Increase productivity and work smarter with ASUS QuickFit Virtual Scale. PA328Q provides you with an onscreen grid overlay so you can align and preview photos and documents in their actual sizes prior to printing. There's also an intuitive 5-way navigation joystick so you can easily access and switch OSD settings on the onscreen menu. When you're spending countless hours working on a project, it's important to have a display with low blue light technology to reduce instances of strained eyes. Say goodbye to tired eyes with ASUS Eye Care technology.
  • Impeccable 4K/UHD visuals
  • Enjoy an expansive workspace
  • Immersing you in truly expressive color
  • 100% sRGB and Rec. 709 color space support for vibrant images
    Appreciate the wonders of beautiful blue skies and lush green forests through a wide-view angle In-plane Switching Technology display with 350cd/m² brightness and 100,000,000:1 ASUS smart contrast ratio. PA328Q offers 10-bit color to display over one billion colors. It uses a 12-bit internal lookup table (LUT) and supports Gamma values of 2.4, 2.2 and 1.8 to give you natural-looking images as well as smoother transitions between hues. There's also customized hue and saturation control with 6-axis color adjustment, so you can adjust red, green, blue, cyan, magenta and yellow hues independently without affecting other colors.
  • Smooth 4K/UHD content playback
    Be immersed in stunning 4K/UHD visuals with the PA328Q. It is equipped with DisplayPort 1.2, mini-DisplayPort 1.2, two HDMI 1.4 ports, and a HDMI 2.0 / MHL 3.0 port. PA328Q supports 4K/UHD content playback at 60Hz through HDMI 2.0 or DisplayPort 1.2, and 30Hz through HDMI 1.4 or MHL 3.0. With a 6ms gray-to-gray response time, the PA328Q gives you smooth video playback and enhanced visuals for work and play.
  • User-friendly features
  • No more tired eyes with ASUS Eye Care technology
  • Say hello to extraordinary comfort
    The ideal viewing position is always within reach with the PA328Q. With a slim profile and ergonomically-designed stand with tilt, swivel, pivot, and height adjustments, the PA328Q provides you with a comfortable viewing angle. It's versatile too, the ability to pivot the screen 90 degrees for use in Portrait mode comes in handy when working with websites or long documents.
ASUS PA328Q - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
67 kWh
Power Consumption (On mode)
46 W
5-way navigation button
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1, HDMI3, MHL: 30 Hz, HDMI2: 60 Hz)
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
100% sRGB
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
73.44 cm x 24 cm x 61.5 cm
11.68 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class B
67 kWh
Diagonal Size
32"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Gamma correction, input select, colour temperature
Picture in picture, Zero Bright Dot, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, Flicker Free technology, ASUS EyeCare Technology, 6-axis colour adjustment, 12-bit lookup table
73.44 cm x 24 cm x 61.5 cm - with stand
11.68 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
Input
2 x HDMI , MHL / HDMI , Headphones , Mini DisplayPort , DisplayPort , 4 x USB 3.0 , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x Mini DisplayPort-DisplayPort cable , 1 x HDMI cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
46 W
Power Consumption (Typical)
138.3 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 73.44 cm - depth: 6.685 cm - height: 43.1 cm , With stand - width: 73.44 cm - depth: 24 cm - height: 61.5 cm - weight: 11.68 kg
Shipping Width
84.7 cm
Shipping Depth
35 cm
Shipping Height
55.2 cm
Shipping Weight
15.74 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
