Product
Asus PA279Q 27" 2560x1440 6ms DVI-D HDMI DisplayPort LED Monitor
Quicklinx: 9DL7WS00 Mfr#: PA279Q
The ASUS PA279Q is pre-calibrated at the factory for the highest accuracy and outstanding color space reproduction - 99% Adobe RGB, 100% sRGB, and 120% NTSC. With a wide color gamut of 99% Adobe RGB, the colors seen in photos will be reproduced faithfully and consistently in a way that cannot otherwise be on monitors with just an sRGB color space.
The PA279Q offers 10-bit display color for over one billion onscreen colors and support 14 bit internal lookup table (LUT), which gives smoother gradations and a more natural transition between hues.
The out-of-box settings are impressive as each PA279Q is pre-calibrated at factory to prove the best color accuracy. To ensure that each PA279Q produces the most accurate and consistent color, we carefully measure its ?E and gamma value and track its gray-scaling.
It even supports Gamma 2.2 for PC and Gamma 1.8 for Mac - offering users more flexibilities to work with. Each PA279Q guarantees industry-leading color accuracy, having been pre-calibrated to minimize the color difference to ?E (Delta E) of less than 2 - ensuring precise reading of color input and guarantees excellent color fidelity.
  • Color consistency for photographer and retouching with 99% Adobe RGB color space
  • 10-bit color for smoother gradations
  • Pre-calibrated right out-of-the box
    The out-of-box settings are impressive as each PA279Q is pre-calibrated at factory to prove the best color accuracy. To ensure that each PA279Q produces the most accurate and consistent color, we carefully measure its ?E and gamma value and track its gray-scaling. It even supports Gamma 2.2 for PC and Gamma 1.8 for Mac - offering users more flexibilities to work with. Each PA279Q guarantees industry-leading color accuracy, having been pre-calibrated to minimize the color difference to ?E (Delta E) of less than 2 - ensuring precise reading of color input and guarantees excellent color fidelity.
  • Next-generation IPS display technology
    The ASUS PA279Q features AH-IPS (Advanced High-Performance In-Plane Switching) display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. Each PA279Q also features a brightness rated at 350cd/m² and an 100,000,000:1 ASUS Smart Contrast Ratio for enhanced image contrast.
  • See better and wider
    The PA279Q WQHD monitor provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals - equaling four times the resolution of stand 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays. The screen's 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PA279Q, power and energy savings are no longer compromised, while better visuals are assured.
  • Made for work and play
    With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27" full HD display, delivering ultra-smooth visuals thanks to 6ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PA279Q is undoubtedly your best choice for work and play.
  • 6-axis independent color adjustment
    Customized hue and saturation control with 6 color adjustment allows you to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
  • Uniformity compensation
    The ASUS PA279Q comes with Uniformity Compensation to help solve problems like brightness and chroma (color) fluctuations on different parts of the screen. The diagram below shows the difference between the luminance recorded at each point on the screen as compared to the central reference point. Ideally, the luminance difference should be within -3% to 2%. You can turn on the Uniformity Compensation function in the OSD to prevent inconsistent and inaccurate color.
  • Robust connectivity
    The PA279Q has a built-in multi-format memory SD card slot and a six-port USB 3.0 hub for convenient pass-through connectivity at speeds up to ten times that of USB 2.0, with compatible devices. One USB port also supports SuperSpeed Battery Charge for accelerated (about 40% faster) USB device recharging than standard USB 3.0.
  • Splendid video intelligence technology
    ASUS Splendid Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user's current task, thereafter adjusting the display's parameters according to ensure color accuracy and image fidelity. Seven preset modes (Scenery, Theater, Adobe RGB, sRGB, standard and two user modes) can be selected via a designated hotkey.
  • Intuitive 5 way navigation key
    The PA279Q has a 5-way navigation key that acts as a joystick that gives access to the QuickFit Virtual Scale function along with all OSD functions and settings.
  • Customizable OSD shortcuts
    The PA279Q also features two user-customizable shortcuts for frequently used monitor controls, removing the need to navigate the full on-screen menu system.
  • Picture-in-Picture and Picture-by-Picture
    ASUS exclusive innovations Picture-in-Picture (PIP) and Picture-by-Picture (PBP) allows users to view images from different signals in almost anyway they want. PIP and PBP let users view images from different signals and let them switch between the main and PIP source, including audio, easily.
  • QuickFit virtual scale function
    ASUS included its exclusive QuickFit Virtual Scale Function with the PA279Q, allowing users to preview photos and documents on screen in their actual sizes prior to printing. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos. Additionally, the PA279Q also comes with a choice of seven different background colors for users to choose from.
  • Ergonomic design
    As with most ASUS displays, the PA279Q is VESA-wall mount compliant and comes with a versatile stand with full tilt, swivel, pivot, and height adjustment. A monitor hood attachment is also supplied for shielding the display from bright ambient light for even greater color accuracy.
ASUS PA279Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
63.7 kWh
Power Consumption (On mode)
43.6 W
5-way navigation button, USB Hub, 9-in-1 card reader
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, 2xDisplayPort
Speakers
Integrated
Display Position Adjustments
64.078 cm x 24 cm x 55.984 cm
10 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, FCC, RoHS, WEEE, PSE Mark, J-MOSS, UkrSEPRO, ERP, CEL, TCO Displays 6.0
3 years warranty
Display Type
Energy Class
Class C
63.7 kWh
43.6 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
49 - 86 Hz
Horizontal Refresh Rate
29 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour balance, gamma correction, input select, colour temperature
Picture in picture, Auto Calibrate, picture by picture, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 100% sRGB colour gamut, 99% Adobe RGB colour gamut, customisable OSD buttons, 120% NTSC colour gamut
64.078 cm x 24 cm x 55.984 cm - with stand
10 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
Input
DVI-D , Headphones , 2 x DisplayPort , HDMI , 6 x USB downstream , USB upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Flat Panel Mount Interface
100 x 100 mm
Detachable hood, cable tie
1 x Mini DisplayPort-DisplayPort cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable , 1 x HDMI cable
49 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 64.078 cm - depth: 6.95 cm - height: 37.968 cm , With stand - width: 64.078 cm - depth: 24 cm - height: 55.984 cm - weight: 10 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years - on-site
