178 wide viewing angle
PA238Q adopts 178 of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it. -
Versatile comfort with ergonomic design
The ergonomically-designed PA238Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. -
Hassle-free connection
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc. -
Mercury-free LED-backlit panel
Embedded LED backlight panel helps power saving and environmental protection with no mercury usage. -
Human sensor integrated for power saving
An integrated human sensor detects the user's presence or absence in front of the monitor. When the user leaves the desk, PA238QR will automatically switch to power saving mode and turn on the monitor once he or she is back, to help reduce energy consumption with inactivity.
- ASUS PA238QR - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class B
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- Presence sensor, USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 50000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Black
- 5.5 kg
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 38 kWh
- Diagonal Size
- 23"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, gamma correction, input select, colour temperature
- Picture in picture, picture by picture, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Color Rich Technology
- Black
- - with stand
- 5.5 kg
- VGA (HD-15) , HDMI , DVI-D , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 120
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, tilt adjustment, swivel adjustment, adjustable height, pivot adjustment
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
- 26 W
- Power Consumption (Typical)
- 33 Watt
- Power Consumption Stand by / Sleep
- 1 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities
- Limited warranty - 3 years
