ASUS PA238Q - LCD display - TFT - LED backlight - 23" - widescreen, HDMI, DVI-D, VGA, - black
Quicklinx: 7PM7WS00 Mfr#: PA238Q
  • High-Definition Multimedia Interface (HDMI)
The Professional Monitor with a Touch of Play
  • IPS panel with 100% sRGB coverage and 178 wide viewing angle
  • Every unit is factory-calibrated for superior color fidelity
  • QuickFit Virtual Scale instantly boosts design efficiency by providing real-size document, photo and grid on screen
Ultimate Color Precision
High Color Accuracy with Low Delta E
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity.
178° Wide Viewing Angle
PA238Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
Flawless Gradation with 10-bit Look-up Table
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution
User-friendly Solutions
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Supporting Formats:
  • Document: A4, letter
  • Photo: 8"x10", 5"x7", 4"x6", 3"x5", 2"x2"
  • Grid: Alignment, Centimeters, Inches
Versatile Comfort with Ergonomic Design
The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position
Customized Color Adjustment
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors
Picture-in-Picture and Picture-by-Picture
Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want
Hassle-Free Connection
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc
Mercury-free LED-backlit panel
Embedded LED backlight panel helps power saving and environmental protection with no mercury usage
  • Ultimate color precision
    PA238Q is pre-calibrated with a maximum Delta E of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. And PA238Q adopts 178° of horizontal and vertical viewing angle and built-in internal 10-bit look-up table result in smooth gradation and accurate color resolution
  • User-friendly solutions
    The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the screen. It can be activated via a hotkey on monitor and used as a guide to accurately view and edit photos. The ergonomically-designed PA238Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
  • Hassle-free connection
    PA238Q comes with rich connectivity including display port, HDMI, DVI, and D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
  • Mercury-free LED-backlit panel
    Embedded LED backlight panel helps power saving and environmental protection with no mercury usage.
ASUS PA238Q - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
100% sRGB (CIE 1976)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
54.9 cm x 20.1 cm x 49.6 cm
5.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, RoHS, ISO 9241-307, WEEE, GOST-R, J-MOSS, ErP Ready
Display Type
Diagonal Size
23"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, colour balance, gamma correction, input select, colour temperature
Picture in picture, picture by picture, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
54.9 cm x 20.1 cm x 49.6 cm - with stand
5.5 kg
VGA , DVI-D , Headphones , DisplayPort , HDMI , 4 x USB downstream , USB upstream (Type B)
Mechanical
Tilt Angle
25
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, tilt adjustment, swivel adjustment, adjustable height, pivot adjustment
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x audio cable
Power Consumption (Typical)
33 Watt
Power Consumption Stand by / Sleep
1 Watt
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
7PM7 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
