Productive and secure yet budget-friendly for SMBs. Now with 3 years on site warranty.
- Windows 8.1 Pro (Free upgrade to Windows 10 Pro) or other editions available
- Stay connected anywhere with dual-band Wi-Fi
- Wake-on-LAN (WOL) allows PCs to be turned on by a simple network message
- Built-in three USB 3.0 ports for ultra-fast data transfer speeds
- Removable large-capacity battery pack for easy servicing and longer battery life
- ASUSPRO Business Center for advanced PC management in one simple software package
- USB Charger+ allows quick charging of mobile devices even when the notebook powered off
- Designed for professionals
- True-comfort keyboard for easier typing and increased productivity
- Large multi-gesture touchpad for precise and intuitive input
- Strain-reducing anti-glare HD panels with wide viewing angle
The ASUSPRO P2420L & P2520L notebooks are designed for SMBs with controlled budgets that demand durable high-end performance and failsafe security. With additional USB ports and replaceable battery, they are highly productive. Budget-friendly, they're the perfect choice for smart up-and-coming businesses on the path to success.
Style and Comfort
The P2420L & P2520L notebooks have a professional look with brushed-hairline aluminum textures and scratch-resistant coating LCD. They are ergonomically designed and feature a seamless one-piece Chiclet keyboard with precise key alignment for ultimate comfort. The anti-glare display has a matte screen surface that prevents unwanted reflections and helps reduce eye fatigue.
Subtly stylish
The ASUSPRO P series uses a one-piece build to create a professional yet subtle look. The design simplicity extends to the underside, with no unnecessary clutter, and a premium look and feel is achieved by the use of abrushed-hairline aluminum textures.
True-comfort keyboard and dedicated numeric keypad increase productivity
Notebook keyboards are of great concern in the workplace, as they are essential for comfort and productivity. ASUS engineers have fine-tuned the P series keyboard, providing optimum key feel and long key travel to maintain comfort during long hours of work. The keyboard also provides a full dedicated numeric keypad, complete with navigation keys, to increase efficiency for data entry or document navigation.
Multi-gesture touchpad - Easier to use and more precise input with scroll, rotate, and zoom
With gesture support, it effectively replaces the mouse, offering an alternative and intuitive input option. Multi-touch input allows effortless accuracy without a mouse, including two-finger web page scroll, zooming and rotating images, plus three-finger tapping to mimic a right-click. Workflow can be streamlined with gesture control, especially multi-step tasks such as presentations and research projects.
Anti-glare display for comfortable viewing
The matte screen surface used in ASUSPRO notebooks prevents unwanted reflections, reducing eye fatigue. It also prevents unsightly fingerprint smudges from spoiling displayed content such as presentations. Ergonomically-angled and textured palm rest areas provide a comfortable and solid feel for optimum productivity.
Work Efficiently
Business and organizational users demand greater productivity and efficiency. The ASUSPRO P2420L & P2520L notebooks are extremely productive. Each one comes with a replaceable battery for easy switching for extended computing or maintenance reasons and both support 4 USB ports - three USB 3.0 and one USB 2.0.
USB 3.0 and USB Charger+ offer ultra-fast transfer speeds and quick device charging
Notebooks ship with USB 3.0 as standard, delivering up to ten times the transfer speeds of USB 2.0. Exclusive ASUS USB Charger+ software easily charges smartphones, media players, and other portable devices even when notebooks are powered off or in sleep/hibernate modes -- in a fraction of the time it would normally take.
Replaceable battery and smart power connect alert
The removable battery pack can be replaced with an optional extended-life battery, and adding an external battery case can even double battery life. It's also easy to replace old batteries when necessary. The P Series also feature a power connector alert that notifies users if the power supply malfunctions or is disconnected, minimizing the risk of sudden shutdowns and interruptions.
Streamlined management
ASUS Business Manager (ABM) is a simple, one-stop manageability and security solution specially designed for small businesses without a managed IT environment. For added security, the embedded TPM Security Chip provides with protection on a deep hardware level. They also feature fingerprint scanning that takes data access authorization and protection to a higher level. It uses sensors that are less affected by skin surface conditions including dry, worn, calloused, dirty or oily skin.
ASUSPRO Business Center for PC management in one simple package
ASUSPRO Business Center is a new computing platform comprising hardware, software and firmware that provides unique security and productivity capabilities. It has been specially designed for small businesses that do not have a managed IT environment, simplifying management and maintenance so you can focus more on your business.
Wake-on-LAN(WOL) allows PCs to be turned on by a simple network message
ASUSPRO P Essential Series have a built-in hardware module on the motherboard that supports Wake-on-LAN (WOL). This allows a computer to be powered on or woken from sleep mode by a network message via LAN connections. This feature is invaluable for remote PC maintenance and support.
Green ASUS
ASUS leads the industry in eco-friendly processes, minimizing environmental impact with an initiative dubbed Green ASUS. It covers four areas: green design, green manufacturing, green procurement, and green services. ASUS is focused on safeguarding our planet with responsible products, and the ASUSPRO Series succeeds in combining a lower total cost of ownership with the highest environmental standards. It is fully EPEAT, Energy Star, and RoHS-certified.
Subtly stylish
The ASUSPRO P series uses a one-piece build to create a professional yet subtle look. The design simplicity extends to the underside, with no unnecessary clutter, and a premium look and feel is achieved by the use of a brushed-hairline aluminum textures. -
The matte screen surface used in ASUSPRO notebooks prevents unwanted reflections, reducing eye fatigue. It also prevents unsightly fingerprint smudges from spoiling displayed content such as presentations. Ergonomically-angled and textured palm rest areas provide a comfortable and solid feel for optimum productivity. -
Multi-gesture touchpad - easier to use and more precise input with scroll, rotate, and zoom
A multi-touch touchpad with ASUS Smart Gesture technology gives you a natural and intuitive input experience. -
Work efficiently
Business and organizational users demand greater productivity and efficiency. The ASUSPRO P2520L notebooks are extremely productive. Each one comes with a replaceable battery for easy switching for extended computing or maintenance reasons and both support 4 USB ports - three USB 3.0 and one USB 2.0. -
The removable battery pack can be replaced with an optional extended-life battery, and adding an external battery case can even double battery life. It's also easy to replace old batteries when necessary. The P Series also feature a power connector alert that notifies users if the power supply malfunctions or is disconnected, minimizing the risk of sudden shutdowns and interruptions. -
Wake-on-LAN allows PCs to be turned on by a simple network message
- ASUSPRO ESSENTIAL P2520LA-XO0956E - 15.6" - Intel Core i7 - 5500U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro + Windows 10 Pro Licence
- Processor
- Intel Core i7 (5th Gen) - 5500U / 2.4 GHz, up to 3 GHz / 4 MB Cache
- Memory
- 4 GB DDR3
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell
- Black texture
- 38 cm x 25.6 cm x 2.63 cm
- 2.37 kg
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional + Windows 10 Pro Licence
Processor / Chipset
- CPU
- Intel Core i7 (5th Gen) 5500U / 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR3 SDRAM
- Slots Qty
- 2
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Image Sensor Type
- CMOS
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-gesture touch pad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
- Technology
- 4-cell Lithium Ion
- Capacity
- 37 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- Interfaces Details
- VGA , HDMI , LAN , USB 2.0 , 3 x USB 3.0 , Headphone/microphone combo jack
- Memory Card Reader
- 3 in 1 (SD Card, Memory Stick, SDHC Card, SDXC Card)
- Black texture
- ASUS USB Charger+, replaceable battery
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- UL, BSMI, CB, CCC, FCC, RoHS, WEEE, GOST-R, CECP, iDA, ErP 2013
- 2.37 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
