Asus NVIDIA GeForce GTX 1080Ti ROG POSEIDON GAMING 11GB GDDR5X
Quicklinx: CXJSWS00 Mfr#: POSEIDON-GTX1080TI-P11G-GAMING
Legendary cooling: air or liquid - your choice to chill. Liquid cooling has evolved to the point where it is not only about delivering superior cooling performance, but also adding personalized style to your gaming system. The ROG Poseidon graphics card delivers on both fronts. With next-gen DirectCU H20 hybrid cooling and Patented Wing-Blade 0dB Fans that let you choose between air and liquid cooling, the ROG Poseidon combines superb performance with convenient flexibility. When it comes to aesthetics, ASUS Aura Sync and a unique, infinite-reflection design provides stunning RGB lighting effects, allowing you to build a gaming system that truly outshines the competition.
ASUS ROG-POSEIDON-GTX1080TI-P11G-GAMING - Platinum Edition - graphics card - GF GTX 1080 Ti - 11 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080 Ti
11 GB GDDR5X
Core Clock
1620 MHz
Boost Clock
1733 MHz
CUDA Cores
3584
Effective Memory Clock
11.1 GHz
Memory Interface
352-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D , 2 x DisplayPort , 2 x HDMI
API Supported
OpenGL 4.5
5 cm x 29.8 cm x 15.8 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1620 MHz
Boost Clock
1733 MHz
CUDA Cores
3584
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Native HDMI, Nvidia CUDA technology, 2.5-slot Fan Cooler, NVIDIA G-Sync ready, ASUS DirectCU H2O Technology, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Aura RGB Lighting, NVIDIA Pascal GPU technology, NVIDIA VRWorks, 10+2 Phase Power Design, ASUS FanConnect II, Patented Wing-Blade IP5X-Certified Fans, standard G1/4-inch terminal block, HDCP
Size
11 GB
GDDR5X SDRAM
Effective Clock Speed
11.1 GHz
Bus Width
352-bit
Additional Requirements
2 x 8 pin PCI Express power connector
Backplate, ROG touch fastener
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
5 cm
29.8 cm
15.8 cm
