Legendary cooling: air or liquid - your choice to chill. Liquid cooling has evolved to the point where it is not only about delivering superior cooling performance, but also adding personalized style to your gaming system. The ROG Poseidon graphics card delivers on both fronts. With next-gen DirectCU H20 hybrid cooling and Patented Wing-Blade 0dB Fans that let you choose between air and liquid cooling, the ROG Poseidon combines superb performance with convenient flexibility. When it comes to aesthetics, ASUS Aura Sync and a unique, infinite-reflection design provides stunning RGB lighting effects, allowing you to build a gaming system that truly outshines the competition.
- ASUS ROG-POSEIDON-GTX1080TI-P11G-GAMING - Platinum Edition - graphics card - GF GTX 1080 Ti - 11 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080 Ti
- Memory
- 11 GB GDDR5X
- Core Clock
- 1620 MHz
- Boost Clock
- 1733 MHz
- CUDA Cores
- 3584
- Effective Memory Clock
- 11.1 GHz
- Memory Interface
- 352-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DVI-D , 2 x DisplayPort , 2 x HDMI
- API Supported
- OpenGL 4.5
- 5 cm x 29.8 cm x 15.8 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1620 MHz
- Boost Clock
- 1733 MHz
- CUDA Cores
- 3584
- VR Ready
- Max Resolution
- 7680 x 4320
- API Supported
- OpenGL 4.5
- Native HDMI, Nvidia CUDA technology, 2.5-slot Fan Cooler, NVIDIA G-Sync ready, ASUS DirectCU H2O Technology, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Aura RGB Lighting, NVIDIA Pascal GPU technology, NVIDIA VRWorks, 10+2 Phase Power Design, ASUS FanConnect II, Patented Wing-Blade IP5X-Certified Fans, standard G1/4-inch terminal block, HDCP
- Size
- 11 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 11.1 GHz
- Bus Width
- 352-bit
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- Included Accessories
- Backplate, ROG touch fastener
- Software Included
- Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
- 5 cm
- 29.8 cm
- 15.8 cm
