Asus NVIDIA GeForce GTX 1050 2GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: CK0BWS00 Mfr#: PH-GTX1050-2G
ASUS Phoenix GeForce GTX 1050 comes equipped with a dual ball-bearing fan for a 2X longer card lifespan and exclusive Auto-Extreme technology with Super Alloy Power II components for superior stability. ASUS Phoenix GeForce GTX 1050 also has GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and real-time streaming.
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS Phoenix GeForce GTX 1050 lasts 2X longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • Your compact build
  • Dual-ball bearing fan
  • Auto-Extreme technology with Super Alloy Power II
    ASUS graphics cards are produced using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • GPU Tweak II with XSplit Gamecaster
    Redesigned with an intuitive UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes graphics performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
  • XSplit Gamecaster - stream and record your gameplay instantly
    Now, you can also launch XSplit Gamecaster to bring up the in-game overlay and start streaming or recording your gameplay with the click of a button. You can also try the in-game annotations and video editor features to enhance your game stream experience.
ASUS PH-GTX1050-2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1354 MHz
Boost Clock
1455 MHz
CUDA Cores
640
Effective Memory Clock
7.008 GHz
Memory Interface
128-bit
Max Resolution
7680 x 4320
DVI-D (dual link) , HDMI , DisplayPort
API Supported
OpenGL 4.5
3.7 cm x 19.2 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1354 MHz
Boost Clock
1455 MHz
CUDA Cores
640
Max Resolution
7680 x 4320
API Supported
OpenGL 4.5
Native HDMI, Dual ball Bearing Fan, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, NVIDIA GPU Boost 3.0, NVIDIA Ansel, NVIDIA Pascal GPU technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.008 GHz
Bus Width
128-bit
Software Included
Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster 2 (14 days Premium licence)
3.7 cm
19.2 cm
11.1 cm
