300Mbps Wireless 802.11N PCI Express adapter for your desktop
Physical WPS (Wi-Fi Protected Setup) button quickly sets up a secure wireless connection.
Software AP mode allows the WLAN card to act as a virtual access point, and connects your notebook, or other game consoles to the Internet.
Support WEP, WPA, and WPA2 encryption methods for enhanced security.
Easily Turn Your Desktop Wireless
The ASUS PCE-N15 is designed to provide complete end-to-end wireless performance from the server or server backbone to the switch infrastructure and down through to the desktop with the PCI Express connector. The PCE-N15 Wireless-N PCI Express Adapter provides wide compatibility, fitting with any standard PCI Express slot, x1, x2, x8, or x16. Compared with standard PCI network cards, it offers increased bandwidth, reliability and more functionality, allowing you to enjoy a fast and advanced connection, such as downloading, making internet calls and video streaming.
Enhanced Security
Supports 64/128-bit WEP,WPA2-PSK,WPA-PSK,WPS security.
For quickly setting up a secure wireless connection, install the utility from the Support CD, then press the hardware WPS button on the PCE-N15 and click "next". Press the hardware WPS button on the router you would like to connect to, and that's it! After the utility finishes the setup procedure, the wireless connection is done!
Software AP Mode
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
For quickly setting up a secure wireless connection, press the hardware WPS button on PCE-N15, then press the WPS button on router as well. Either you can choose to use WPS button, enabling the WPS utility in the WPS wizard interface. -
Software AP
- ASUS PCE-N15 - network adapter - PCIe
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- 12.1 cm x 2.2 cm x 2.2 cm
- 63 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- Network adapter
- Form Factor
- PCI Express
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- OFDM
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, OFDM
- Frequency Band
- 2.4 GHz
- Software access point, WPS
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 2 x aerial - R-SMA
- Compatible Slots
- 1 x PCI Express
- Included Accessories
- Low-profile bracket
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- C-Tick, IC, FCC
- Software Included
- Drivers & Utilities
- OS Required
- 12.1 cm
- 2.2 cm
- 2.2 cm
- 63 g
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
