Product
Asus MX34VQ 34" Curved 3440 x 1440 4ms HDMI Monitor
Quicklinx: CWDRWS00 Mfr#: MX34VQ
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
Hurry, only 3 left in stock!
£659.72 ex VAT
£791.66 inc VAT
Inspired elegance. Immersive experience.
Perfectly curved for immersive visuals
Take home entertainment to the next level with the ASUS Designo MX34VQ curved display. The 34-inch, ultra-wide QHD Designo monitor has a 21:9 aspect ratio and a 1800R curved screen for a wider field of view. The Designo MX34VQ features 178┬░wide-view technology across its horizontal and vertical planes, allowing you to enjoy beautiful visuals from almost any angle.
Ultra-wide QHD for incredibly detailed images
The ultra-wide QHD of the Designo display features 2.5x the resolution of a Full HD display, so it provides 35% more onscreen space than other Full HD displays of a similar size. The extra resolution makes multitasking more enjoyable and more efficient.
High contrast ratio for vibrant colors
The ultra-high 3000:1 contrast ratio of the Designo produces the brightest whites and the darkest black hues, delivering exceptionally distinct imagery.
Built-in Qi wireless charger
Messy wiring and misplaced chargers are a thing of the past with the Designo MX34VQ. Its transparent base has a built-in Qi wireless charger that automatically charges Qi-compatible devices the moment they are placed on the base. The base has built-in LEDs and emits an aurora-like glow during charging.
ASUS MX34VQ - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
108 kWh
Power Consumption (On mode)
74 W
Curved Screen
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
3xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Dark grey, plasma cooper
81.06 cm x 45.68 cm x 23.97 cm
8.4 kg
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, J-MOSS, ERP, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
Display Type
Energy Class
Class C
108 kWh
74 W
Diagonal Size
34"
Curved Screen
Yes (1800R)
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 151 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, HDCP, frameless, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS GamePlus, ASUS VividPixel Technology, Flicker Free technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection, Qi Wireless charging
81.06 cm x 45.68 cm x 23.97 cm - with stand
8.4 kg
Audio
Speakers - stereo
Output Power / Channel
8 Watt
3 x HDMI , DisplayPort , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
1 x DisplayPort cable , 1 x HDMI cable
100 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Diagonal Size: 34in
Response Time: 4ms
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: 500 - 750
