Inspired elegance. Immersive experience.
Perfectly curved for immersive visuals
Take home entertainment to the next level with the ASUS Designo MX34VQ curved display. The 34-inch, ultra-wide QHD Designo monitor has a 21:9 aspect ratio and a 1800R curved screen for a wider field of view. The Designo MX34VQ features 178°wide-view technology across its horizontal and vertical planes, allowing you to enjoy beautiful visuals from almost any angle.
Ultra-wide QHD for incredibly detailed images
The ultra-wide QHD of the Designo display features 2.5x the resolution of a Full HD display, so it provides 35% more onscreen space than other Full HD displays of a similar size. The extra resolution makes multitasking more enjoyable and more efficient.
High contrast ratio for vibrant colors
The ultra-high 3000:1 contrast ratio of the Designo produces the brightest whites and the darkest black hues, delivering exceptionally distinct imagery.
Built-in Qi wireless charger
Messy wiring and misplaced chargers are a thing of the past with the Designo MX34VQ. Its transparent base has a built-in Qi wireless charger that automatically charges Qi-compatible devices the moment they are placed on the base. The base has built-in LEDs and emits an aurora-like glow during charging.
- ASUS MX34VQ - LED monitor - curved - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class C
- Energy Consumption per Year
- 108 kWh
- Power Consumption (On mode)
- 74 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- UWQHD 3440 x 1440 at 100 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 3xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Dark grey, plasma cooper
- 81.06 cm x 45.68 cm x 23.97 cm
- 8.4 kg
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, J-MOSS, ERP, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
- Display Type
- Energy Class
- Class C
- 108 kWh
- Diagonal Size
- 34"
- Curved Screen
- Yes (1800R)
- Panel Type
- VA
- Aspect Ratio
- 21:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 151 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Picture in picture, HDCP, frameless, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, ASUS GamePlus, ASUS VividPixel Technology, Flicker Free technology, Blue Light Filter technology, Adaptive-Sync technology, Colour Temperature Selection, Qi Wireless charging
- 81.06 cm x 45.68 cm x 23.97 cm - with stand
- 8.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 8 Watt
- 3 x HDMI , DisplayPort , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable
- Input Voltage
- 74 W
- Power Consumption (Typical)
- 100 Watt
- 0.5 Watt
- On / Off Switch
- No
- Shipping Width
- 94.7 cm
- Shipping Depth
- 29.5 cm
- Shipping Height
- 58.4 cm
- Shipping Weight
- 13.5 kg
