Asus MX299Q 29" Wide AH-IPS LED Silver/Black Multimedia Monitor
Full panoramic visual and audio experience: ultra-wide 21:9 2560x1080
Quicklinx: 8XNPWS00 Mfr#: MX299Q
Diagonal Size: 29in
Max Resolution: 2560 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL)
£315.98 ex VAT
£379.17 inc VAT
The ASUS MX series design was inspired by the concentric style of a sundial - a masterpiece of innovation created over a millennia ago. The ASUS design processes follow a similar line of thinking: simple yet innovative, natural yet empowering. The ASUS design team found inspiration in the sundial concept, and crafted a stand that symbolizes complete flexibility, professionalism, and meticulous art.
A masterful culmination of advanced technology and artistic design, the Designo series MX299Q ultra-wide 21:9 cinematic monitor represents the current state of the art in PC monitors. A sleek 29-inch AH-IPS display with an ultra-wide 21:9 ratio and 2560 x 1080 resolutions, the MX229Q delivers a 33% larger display area compared to a Full HD monitor for the best theater-like home entertainment. What's more, the MX299Q has an edge-to-edge, frameless cinematic display for an ideal multi display setup and stylish design.
  • Beauty beyond boundaries
    The ASUS MX series design was inspired by the concentric style of a sundial - a masterpiece of innovation created over a millennia ago. The ASUS design processes follow a similar line of thinking: simple yet innovative, natural yet empowering. The ASUS design team found inspiration in the sundial concept, and crafted a stand that symbolizes complete flexibility, professionalism, and meticulous art. A masterful culmination of advanced technology and artistic design, the Designo series MX299Q ultra-wide 21:9 cinematic monitor represents the current state of the art in PC monitors. A sleek 29-inch AH-IPS display with an ultra-wide 21:9 ratio and 2560 x 1080 resolutions, the MX229Q delivers a 33% larger display area compared to a Full HD monitor for the best theater-like home entertainment. What's more, the MX299Q has an edge-to-edge, frameless cinematic display for an ideal multi display setup and stylish design.
  • Ultra-wide resolution enhances work and play
    With a display area equivalent to that of two 17-inch (5:4 aspect ratios) monitors placed alongside each other, the ASUS Designo series MX299Q ultra-wide 21:9 cinematic monitor has a display area 33% wider than a Full HD monitor. The 21:9 aspect ratios gives you more screen real estate for working with multiple windows side-by-side as you would with a secondary display. The 2560 x 1080 resolution also means there are no black bars above and below the image when watching widescreen 2.35:1 movies and gamers can also enjoy games in immersive cinematic widescreen. The LED-backlit AH-IPS display has extremely accurate color reproduction that makes the MX299Q ideally suited for both professional and home use. A 178-degree wide viewing angles also ensures minimal color distortion for enhanced screen sharing.
  • Incredibly subtle yet sophisticated
    The MX299Q features an ultra-slim profile measuring just 16.4 mm at its thinnest point. ASUS Designo series MX monitors have received numerous design accolades that include the 2012 Japan Good Design Award. The MX299Q also won a 2013 CES innovations awards in the video displays category.
  • QuickFit virtual scale
    With a simple hotkey, you can preview your photos and documents on screen in their actual sizes prior to printing; or work with an alignment grid to ensure everything is straight and true.
  • SPLENDID Video Intelligence technology
    ASUS SPLENDID is built upon a color engine that automatically analyzes and determines the nature and parameters of current visual tasks, adjusting display parameters to ensure optimal color accuracy and image fidelity.
ASUS MX299Q - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Full HD UWQHD 2560 x 1080
Brightness
300 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours (8-bit)
Input Connectors
DVI-D, DisplayPort, HDMI (MHL)
Speakers
Integrated
Display Position Adjustments
Tilt
Black, silver
70.02 cm x 21.51 cm x 39.1 cm
5.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, J-MOSS, ErP Ready
Display Type
Energy Class
Class B
57 kWh
39 W
Diagonal Size
29"
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, gamma correction, input select
sRGB colour management, HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, 100% sRGB colour gamut
Black, silver
70.02 cm x 21.51 cm x 39.1 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
DisplayPort , HDMI , DVI-D , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower
1 x HDMI cable , 1 x DVI cable , 1 x audio cable , 1 x Mobile High-Definition Link (MHL) cable
Security Slot Type
Kensington security slot
21.92 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Included Software
ASUS MultiFrame
Shipping Width
81.4 cm
Shipping Depth
15.9 cm
Shipping Height
50.6 cm
Shipping Weight
8.1 kg
ENERGY STAR Certified
Asus MX299Q 29 Bundle deal on Asus MX299Q 29" Wide AH-IPS LED Silver/Black Multimedia Monitor
£415.15
8XNP C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8XNP C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.80
8XNP C2G 5m Select High Speed HDMI with Ethernet In Stock £22.72
8XNP C2G 10m Select High Speed HDMI with Ethernet In Stock £43.63
8XNP C2G 15m Select High Speed HDMI with Ethernet In Stock £59.09
Diagonal Size: 29in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: Mobile High-Definition Link (MHL)
Brand: Asus
Price Range Ex VAT: 300 - 500
