Asus MX27UQ 27" 3840x2160 4K IPS UHD HDMI Monitor
Quicklinx: C2VDWS00 Mfr#: MX27UQ
ASUS Designo MX27UQ feels right at home in any living space, with a space-saving ultra-slim profile and an exquisite edge-to-edge frameless panel. With a high pixel density, it gives you sharper images with more details and textures. Having a higher pixel count also means more efficient multitasking. Whether you're watching 4K Ultra HD video streams online, or re-watching your own video clips, the Designo MX27UQ lets you fully enjoy them in all their glory.
  • Exquisite ultra-slim, frameless design
  • A true work of art
    Through exquisite metal craftsmanship and an uncompromising attention to detail, Designo MX27UQ features amazing design with simplistic classic lines and a sturdy sundial-inspired base stand.
  • See better with 4K Ultra HD resolution
    Designo MX27UQ delivers 4K Ultra HD visuals with stunning levels of detail. With a high pixel density, it gives you sharper images with more details and textures. Having a higher pixel count also means more efficient multitasking. Whether you're watching 4K Ultra HD video streams online, or re-watching your own video clips, the Designo MX27UQ lets you fully enjoy them in all their glory.
  • Stunning 178° wide viewing angles
    Designo MX27UQ has an advanced high-performance IPS panel that provides an astonishing contrast ratio and 178-degree wide viewing angles. This LED-backlit display covers the entire sRGB color space ensuring extremely accurate color reproduction for professional-grade photo and video editing, or for home entertainment.
  • Powerful, immersive audio
    To match those incredible visuals, Designo MX27UQ utilizes a combination of advanced audio hardware and professional audio processing with built-in dual stereo speakers for fully-immersive sound. ASUS SonicMaster audio technology refines every acoustic detail to deliver crystal-clear sound with more distinct vocals, wide frequency range, and incredible audio fidelity.
  • Wireless music streaming
    You can even connect your Bluetooth-enabled smart phones and tablets to Designo MX27UQ to enjoy your favorite music wirelessly. Bluetooth wireless technology and ICEpower Bang & Olufsen-powered audio let you enjoy high-quality music streams, even with your monitor in standby mode.
  • AudioWizard provides flexibility of preference
    Designo MX27UQ features ASUS AudioWizard for optimized audio settings to suit the task at hand. You can access its four pre-set modes via the onscreen display (OSD) menu.
  • Flicker-Free technology
    It is time to say goodbye to those tired, strained eyes. Designo MX27UQ features ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
  • SplendidPlus Video Intelligence technology
    Designo MX27UQ features ASUS SplendidPlus technology to provide you with optimized visuals by enhancing color brightness, contrast, and sharpness. It has eight preset modes allowing you to select the one that best suits the content you're currently viewing.
  • QuickFit Virtual Scale
    A hotkey lets you preview your photos and documents on screen in their actual sizes prior to printing and also provides you with an alignment grid to ensure everything is straight and true.
ASUS MX27UQ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 30 Hz, HDMI2: 60 Hz)
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
Black, icicle gold
61.44 cm x 22.54 cm x 42.95 cm
5.5 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class B
47 kWh
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.155 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
40 - 76 Hz
Horizontal Refresh Rate
29 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Input select, colour temperature
HDCP, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
Black, icicle gold
61.44 cm x 22.54 cm x 42.95 cm - with stand
5.5 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DisplayPort , 2 x HDMI , Headphones , USB
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), ASUS SonicMaster, Stereo Bluetooth Wireless Technology, Bang & Olufsen ICEpower, frameless, Asus AudioWizard
1 x HDMI cable , 1 x DisplayPort cable , 1 x power cable
Input Voltage
32 W
Power Consumption (Typical)
52 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
