The ASUS Designo MX27AQ is a premium monitor that integrates ASUS' frameless display technology and a bespoke style from the ASUS Design Team. Inside, B&O ICEpower stereo speakers combine with ASUS exclusive SonicMaster technology featuring AudioWizard EQ, which is all built right into the monitor.
At 27-inches, the WQHD resolution in-plane switching spec LCD panel is ideal for those looking at a next-gen monitor that doesn't use the typical black plastic construction, without opting for something like a HDTV. Other features ASUS EyeCare technology that combines flicker-free backlight, low-blue light and anti-glare technologies to greatly reduce eyestrain in extended use.
- ASUS MX27AQ - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 24 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB, 76% NTSC
- Input Connectors
- 2xHDMI, DisplayPort, MHL
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver, space grey
- 61.44 cm x 22.54 cm x 42.95 cm
- 5.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, RCM
- Display Type
- Energy Class
- Class A+
- 35 kWh
- Diagonal Size
- 27"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.233 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 28 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Colour temperature
- HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, Low Blue Light Mode, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
- 61.44 cm x 22.54 cm x 42.95 cm - with stand
- 5.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- DisplayPort , 2 x HDMI , MHL / HDMI , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower, frameless, Asus AudioWizard
- Cables Included
- 1 x HDMI cable
- Power Supply
- External
- Input Voltage
- 24 W
- Power Consumption (Typical)
- 38.67 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
