Asus MX27AQ 27" 2560x1440 5ms DVI HDMI DP IPS Gaming Monitor
Quicklinx: BJWJWS00 Mfr#: MX27AQ
The ASUS Designo MX27AQ is a premium monitor that integrates ASUS' frameless display technology and a bespoke style from the ASUS Design Team. Inside, B&O ICEpower stereo speakers combine with ASUS exclusive SonicMaster technology featuring AudioWizard EQ, which is all built right into the monitor.
At 27-inches, the WQHD resolution in-plane switching spec LCD panel is ideal for those looking at a next-gen monitor that doesn't use the typical black plastic construction, without opting for something like a HDTV. Other features ASUS EyeCare technology that combines flicker-free backlight, low-blue light and anti-glare technologies to greatly reduce eyestrain in extended use.
Display Type
Energy Class
Class A+
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
28 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour temperature
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), 100% sRGB colour gamut, ASUS GamePlus, Low Blue Light Mode, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology, 76% NTSC colour gamut
Black, silver, space grey
61.44 cm x 22.54 cm x 42.95 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
DisplayPort , 2 x HDMI , MHL / HDMI , Headphones , Audio line-in
Mechanical
Display Position Adjustments
Tilt
Tilt Angle
-5/+22
Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower, frameless, Asus AudioWizard
1 x HDMI cable
Compatible with Windows 7
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, RCM
Power Supply
External
38.67 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Environmental Standards
ENERGY STAR Certified
