Asus MX27AQ 27" 2560x1440 5ms DVI HDMI DP IPS Gaming Monitor
Quicklinx: BJWJWS00 Mfr#: MX27AQ
The ASUS Designo MX27AQ is a premium monitor that integrates ASUS' frameless display technology and a bespoke style from the ASUS Design Team. Inside, B&O ICEpower stereo speakers combine with ASUS exclusive SonicMaster technology featuring AudioWizard EQ, which is all built right into the monitor.
At 27-inches, the WQHD resolution in-plane switching spec LCD panel is ideal for those looking at a next-gen monitor that doesn't use the typical black plastic construction, without opting for something like a HDTV. Other features ASUS EyeCare technology that combines flicker-free backlight, low-blue light and anti-glare technologies to greatly reduce eyestrain in extended use.
ASUS MX27AQ - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
35 kWh
Power Consumption (On mode)
24 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB, 76% NTSC
Input Connectors
2xHDMI, DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Black, silver, space grey
61.44 cm x 22.54 cm x 42.95 cm
5.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, RCM
Display Type
Energy Class
Class A+
35 kWh
Diagonal Size
27"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB, 76% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
28 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Colour temperature
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, Mobile High-Definition Link (MHL), ASUS GamePlus, Low Blue Light Mode, ASUS SplendidPlus Video Intelligence Technology, ASUS EyeCare Technology
61.44 cm x 22.54 cm x 42.95 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
DisplayPort , 2 x HDMI , MHL / HDMI , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+22
Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower, frameless, Asus AudioWizard
1 x HDMI cable
Power Supply
External
Input Voltage
24 W
Power Consumption (Typical)
38.67 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Sustainability Information
ENERGY STAR Certified
