Inspired by millennia of artistic legacy, the Designo MX Series sports an elegant and precision-crafted sundial design. The MX259H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ technology for incredible visuals. In addition, built-in ASUS SonicMaster technology, co-developed with Bang & Olufsen ICEpower, delivers immersive premium audio performance.
ASUS Designo MX Series displays sport ultra-slim profiles — with MX259H measuring just 15mm at its thinnest point– thereby minimizing desk space requirements. In addition, the MX Series presents an edge-to-edge frameless screen with bezel thickness of just 0.8mm. This subtle but elegant design is further accentuated by a sundial-inspired stand which provides a sturdy base for the monitor.
Beauty beyond boundaries
Inspired by millennia of artistic legacy, the new Designo MX Series sports an elegant and precision-crafted sundial design. The MX259H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ technology for incredible visuals. In addition, built-in ASUS SonicMaster technology, co-developed with Bang & Olufsen ICEpower, delivers immersive premium audio performance. -
Subtle & elegant design
SUS Designo MX Series displays sport ultra-slim profiles - with MX259H measuring just 15mm at its thinnest point - thereby minimizing desk space requirements. In addition, the MX Series presents an edge-to-edge frameless screen with bezel thickness of just 0.8mm. This subtle but elegant design is further accentuated by a sundial-inspired stand which provides a sturdy base for the monitor. -
The powerful IPS technology with 178° wide-view angles
Designo MX259H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. -
Built tough and gamer-centric comfortable
Tracer Free Technology improves the response time of ASUS monitors, eliminating ghosting and tracers during video playback. It does this by controlling voltage levels, resulting in 5ms response time so MX259H provides fluid and clear video playback with silky-smooth motion during gameplay. -
ASUS Smart Contrast Ratio for lifelike visuals
With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, MX259H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals. -
ASUS Eye Care Technology
MX259H provides Eye Care features - Flicker-free and Low Blue Light that prevent your eyes from fatigue and strain and many possible eye symptoms that caused by screen flicker and hazard blue light. MX259H has undergone stringent performance tests and is certified Flicker-free and Low Blue Light by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services. -
QuickFit Virtual Scale for true what you see is what you get
ASUS includes its exclusive QuickFit Virtual Scale feature with the MX259H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. -
Premium Immersive Audio
The Designo MX259H features ASUS SonicMaster technology - which was co-developed by the ASUS Golden Ear team and Bang & Olufsen ICEpower. This ASUS-exclusive audio technology combines advanced hardware and software to refine every acoustic detail in pristine quality to deliver crystal clear, true-to-life surround sound - reproducing richer and more distinct vocals at a wider frequency range and louder volumes. -
Audio by Bang & Olufsen ICEpower
ASUS MX259H delivers outstanding images and stunning graphics that deserve superior sound to complete multimedia experiences whether watching movies, gaming, or listening to music. It features state-of-the-art audio technology from Bang & Olufsen ICEpower, with great sound packed into its slim form factor to create incredibly engaging sound quality. This means no investment in additional speakers is needed.
- ASUS MX259H - LED monitor - Full HD (1080p) - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class A+
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 20 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.288 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, VGA
- Speakers
- Integrated
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 57.8 cm x 22.4 cm x 41.4 cm
- 4.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, WEEE, PSE Mark, GOST-R, J-MOSS, ErP Ready, TUV Rheinland Low Blue Light Certification, CEL level 0, TUV Rheinland Flicker Free Certification
- Display Type
- Energy Class
- Class A+
- 30 kWh
- Diagonal Size
- 25"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.288 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select
- HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, MobileSound 3 technology, blue light reduction, ASUS EyeCare Technology
- Black, silver
- 57.8 cm x 22.4 cm x 41.4 cm - with stand
- 4.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- VGA , 2 x HDMI , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower
- Cables Included
- 1 x VGA cable , 1 x audio cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 20 W
- Power Consumption (Typical)
- 35 Watt
- 0.5 Watt
- Shipping Width
- 65.9 cm
- Shipping Depth
- 11.7 cm
- Shipping Height
- 46.9 cm
- Shipping Weight
- 6.4 kg
Sustainability Information
- ENERGY STAR Certified
