Product
Brand
Asus MX259H 25" 1920x1080 5ms VGA HDMI IPS LED Frameless Monitor with Speakers
Beauty Beyond Boundaries Full HD IPS LED-backlit & Frameless Monitor
Quicklinx: BGD1WS00 Mfr#: MX259H
Inspired by millennia of artistic legacy, the Designo MX Series sports an elegant and precision-crafted sundial design. The MX259H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ technology for incredible visuals. In addition, built-in ASUS SonicMaster technology, co-developed with Bang & Olufsen ICEpower, delivers immersive premium audio performance.
ASUS Designo MX Series displays sport ultra-slim profiles — with MX259H measuring just 15mm at its thinnest point– thereby minimizing desk space requirements. In addition, the MX Series presents an edge-to-edge frameless screen with bezel thickness of just 0.8mm. This subtle but elegant design is further accentuated by a sundial-inspired stand which provides a sturdy base for the monitor.
ASUS MX259H - LED monitor - Full HD (1080p) - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class A+
Energy Consumption per Year
30 kWh
Power Consumption (On mode)
20 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.288 mm
Brightness
250 cd/m²
Contrast Ratio
80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Black, silver
57.8 cm x 22.4 cm x 41.4 cm
4.3 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, GOST-R, J-MOSS
3 years warranty
Display Type
Energy Class
Class A+
30 kWh
20 W
Diagonal Size
25"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.288 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select
HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale, MobileSound 3 technology, blue light reduction, ASUS EyeCare Technology
Black, silver
57.8 cm x 22.4 cm x 41.4 cm - with stand
4.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
VGA , 2 x HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower, Flicker-free technology
1 x VGA cable , 1 x audio cable
35 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
