Asus Mini PC PB40 BC154ZD Intel Celeron N4100 4GB 64GB Windows 10 Professional 64-bit
Quicklinx: FH08WS00 Mfr#: PB40-BC154ZD-OSS
Processor Type: Celeron
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 64GB
Storage Type: SSD
  • Celeron
£222.57 ex VAT
£267.08 inc VAT
ASUS Mini PC PB40 packs versatile desktop-computing power into stylish metal case that's just 17.5cm square, and a mere 3.4cm slim. Inside compact chassis is the latest Intel® Celeron® processor, with optional fanless(1) design for operation that's totally silent. The one-liter volume is no barrier to connectivity, with built-in Wi-Fi and USB 3.1 Gen 1 Type-C™ for simple, quick data transfers. Mini PC PB40 even has a flexible I/O port(2), so you're free to choose a DisplayPort, VGA or COM socket to best fit the needs of your business.
(1)Fanless design is only available on select models
(2)Flexible I/O ports availability may vary by model or region
  • Loaded with connectivity
    ASUS Mini PC PB40 packs in all the connectivity you'd expect from a modern desktop computer - and more besides. As well as USB 3.1 Gen 1 Type-A and Type-C, USB 2.0 and standard 3.5 mm audio jacks, Mini PC PB40 also boasts integrated Wi-Fi plus an antenna connector for improved wireless reception.
  • Comprehensive protection, inside and out
    ASUS Mini PC PB40 is built with multiple safeguards and security features to protect itself and your personal or business information. These include an industry-standard Kensington lock slot to prevent theft and an intrusion alert that warns you if Mini PC PB40's chassis has been opened since last launch.
  • Tested for perfection
    ASUS Mini PC PB40 has undergone rigorous noise, vibration, drop, and thermal shock tests to ensure it meets exacting ASUS standards and exceeds industry requirements. This offers the assurance that Mini PC PB40 can cope with extreme conditions - ranging from dry -40 °C temperatures to humid, hot environments exceeding 60 °C - for long periods of time.
ASUS Mini PC PB40 BC154ZD - mini PC - Celeron N4100 - 4 GB - SSD 64 GB
Personal computer - mini PC
Intel Celeron N4100 (Quad-Core)
RAM
4 GB (installed) / 8 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 64 GB - eMMC
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 600
GigE, 802.11ac, Bluetooth 5.0
OS Provided
17.5 cm x 17.5 cm x 3.42 cm
700 g
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Mini PC
Processor / Chipset
CPU
Intel Celeron N4100
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB / 8 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD - eMMC
1 x 64 GB
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 5.0
Wi-Fi CERTIFIED
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 M.2 Card
2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 5 x USB 3.1 Gen 1 (4 front, 1 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) , 1 x USB 2.0 (1 rear) , 1 x serial
VESA mounting kit
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion alarm
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, C-Tick, BSMI, CB, CCC, FCC
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
ENERGY STAR Certified
17.5 cm
17.5 cm
3.42 cm
700 g
Storage Type: SSD
Processor Model: N4100
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 150 - 300
