Asus MG28UQ 28" 3840x2160 1m 4K HDMI LED Monitor
Quicklinx: C2V7WS00 Mfr#: MG28UQ
Gaming at Your Command
  • 28-inch 4K UHD (3840 x 2160) monitor for stunning photo-realistic visuals.
  • Lightning-fast 1ms rapid response time and Adaptive-Sync technology for incredibly-smooth and fast gaming visuals.
  • DisplayPort 1.2, HDMI(v 2.0) for 4K UHD playback; two USB 3.0 ports for quick-charging to your mobile devices.
  • ASUS-exclusive Ultra-Low Blue Light, Flicker-Free, GamePlus, and GameVisual technologies provide tactical assistance on your command.
A 28-inch 4K UHD display for highly-detailed visuals and more onscreen space
With its 28-inch 4K UHD display, ASUS MG28UQ gives you stunning 3840 x 2160 resolution visuals with a pixel density of 157PPI for incredible photo-realistic visuals and sharp, crisp text. The MG28UQ gives you four times the pixels of similar-sized Full HD 1080p displays so you get more detailed images when playing games or watching movies, as well as more onscreen desktop space for your various work windows. MG28UQ draws you into immersive virtual worlds, with greatly-textured elements and terrain maps that boast impressive levels of detail.
Even with today's fastest games, ASUS MG28UQ eliminates smearing and motion blur thanks to a 1ms response time – the fastest in its class. This astonishing visual performance lets you react instinctively to what you see onscreen, so you can take corners like a pro race car driver, or take an enemy out with a headshot as he peeks around cover. In addition, Adaptive-Sync technology eliminates screen tearing and choppy frame rates for even more seamlessly smooth gameplay.
Robust connectivity
Whether you're playing games or streaming videos, ASUS MG28UQ gives you smooth 4K UHD content playback, thanks to a 60Hz refresh rate and native 4K UHD support via DisplayPort 1.2, HDMI(v 2.0). In addition to its array of connectivity options, the MG28UQ even features two USB 3.0 port that lets you quick-charge your mobile devices while gaming;. Command, control, and charge your phone with a double USB 3.0 array, perfect for your keyboard and mouse of choice.
ASUS-exclusive GamePlus technology
ASUS MG28UQ features the ASUS-exclusive GamePlus hotkey to give you in-game enhancements that help you get more out of your game.
Crosshair
You can choose between four persistent crosshairs and fine tune their position, ensuring pinpoint accuracy in first-person shooters. Enjoy perfect aim even when the game doesn't provide its own crosshair or sights.
ASUS-exclusive GameVisual technology
ASUS GameVisual Technology gives you six preset display modes tailored to suit different types of scenarios. This unique feature can be easily accessed through a hotkey or the On Screen Display (OSD) settings menu.
Ultra-Low Blue Light technology
ASUS Ultra-Low Blue Light technology reduces the amount of harmful blue light emitted by ASUS MG28UQ. You can access and select four different filter settings onscreen easily through the OSD menu to find the best one that suits the task at hand.
Low Blue Light Level
The MG28UQ gaming monitor has undergone stringent performance tests and is certified by TÜV Rheinland laboratories, a global provider of technical, safety, and certification services, to be flicker-free and to emit low blue light levels.
Flicker-Free technology
Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
Ergonomic design
ASUS MG28UQ is specially designed for long marathon gaming sessions. Its ergonomically-designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor so you always find your ideal viewing position. A quick-release latch lets you separate the MG28UQ from its stand so you can mount it on a wall.
  • 28" Ultra HD display for highly detailed visuals
    With its 28" Ultra HD display, the ASUS MG28UQ gives you stunning visuals for incredible realistic visuals and sharp, crisp text. You get more detailed images when playing games or watching movies, as well as more desktop space for your various work windows. The MG28UQ draws you into immersive virtual worlds, with greatly textured elements and terrain maps that boast impressive levels of detail.
  • Lightning-fast response time
    The ASUS MG28UQ eliminates smearing and motion blur thanks to a 1 ms response time. This astonishing visual performance lets you react instinctively to what you see in the display, so you can take corners like a pro race car driver, or take an enemy out with a headshot as he peeks around cover.
  • Robust connectivity
    Whether you're playing games or streaming videos, the ASUS MG28UQ gives you smooth Ultra HD content playback, thanks to a 60 Hz refresh rate and native Ultra HD support via the DisplayPort. In addition to its array of connectivity options, the MG28UQ features two USB 3.0 ports that let you quickly charge your mobile devices while gaming.
  • Ultra-low blue light technology
    The ultra-low blue light technology reduces the amount of harmful blue light emitted by the MG28UQ. You can access and select different filter settings easily through the OSD menu to find the one that suits the task at hand.
  • Ergonomic design
    The MG28UQ is specially designed for long marathon gaming sessions. Its ergonomically designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor so you always find your ideal viewing position. A release latch lets you separate the MG28UQ from its stand so you can mount it on a wall.
ASUS MG28UQ - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
62 kWh
Power Consumption (On mode)
42 W
Adaptive-Sync Technology
VESA Adaptive-Sync
5-way joystick, USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI1: 60 Hz, HDMI2-3: 30 Hz)
Pixel Pitch
0.16 mm
Brightness
330 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
3xHDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
66.026 cm x 23.34 cm x 56.6 cm
8 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, PSE Mark, MEPS, J-MOSS, UkrSEPRO, ERP, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
62 kWh
Diagonal Size
28"
VESA Adaptive-Sync
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Pixel Per Inch
157
Brightness
330 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Input select, colour temperature
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, Crosshair Display, ASUS GameVisual Technology
66.026 cm x 23.34 cm x 56.6 cm - with stand
8 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
5-way joystick
DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream , 3 x HDMI , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
42 W
Power Consumption (Typical)
62.9 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 66.026 cm - depth: 6.74 cm - height: 38.067 cm , With stand - width: 66.026 cm - depth: 23.34 cm - height: 56.6 cm - weight: 8 kg
Shipping Width
77.7 cm
Shipping Depth
22.4 cm
Shipping Height
46.7 cm
Shipping Weight
11 kg
ENERGY STAR Certified
