The MB169C+ is a 15.6-inch portable companion monitor that uses a single USB Type-C connection for both power and video transmission. It is a wide QHD monitor with a 2000R curvature. MB169C+ has a Full HD IPS panel that delivers stunning resolution visuals with an advanced color reproduction, as well as wide viewing angles for minimal color shift even when viewed from extreme positions.
- ASUS MB169C+ - LED monitor - Full HD (1080p) - 15.6"
- LED-backlit LCD monitor - 15.6"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.179 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 700:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- USB
- Black, silver
- 37.9 cm x 0.85 cm x 23.6 cm
- 800 g
- UL, TUV, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, UkrSEPRO, RCM, TUV Rheinland Low Blue Light Certification, CU
- 3-year warranty
- Display Type
- Diagonal Size
- 15.6"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.179 mm
- Brightness
- 220 cd/m²
- Contrast Ratio
- 700:1 (dynamic)
- Response Time
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness
- ASUS QuickFit Virtual Scale, ASUS GamePlus, Slim Design, Blue Light Filter technology
- Black, silver
- 800 g
- USB-C
- Flicker-free technology
- Included Accessories
- Carrying case with display stand
- Cables Included
- 1 x DisplayPort / USB-C cable
- 7 Watt
- OS Required
- Apple MacOS, Windows 10
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
