Asus MB169C+ 15.6" Full HD USB-TypeC Portable USB Monitor
Quicklinx: DHP8WS00 Mfr#: MB169C+
Diagonal Size: 15.6in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: USB
42 in stock
£175.92 ex VAT
£211.10 inc VAT
The MB169C+ is a 15.6-inch portable companion monitor that uses a single USB Type-C connection for both power and video transmission. It is a wide QHD monitor with a 2000R curvature. MB169C+ has a Full HD IPS panel that delivers stunning resolution visuals with an advanced color reproduction, as well as wide viewing angles for minimal color shift even when viewed from extreme positions.
ASUS MB169C+ - LED monitor - Full HD (1080p) - 15.6"
LED-backlit LCD monitor - 15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.179 mm
Brightness
220 cd/m²
Contrast Ratio
700:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Input Connectors
USB
Black, silver
37.9 cm x 0.85 cm x 23.6 cm
800 g
UL, TUV, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, UkrSEPRO, RCM, TUV Rheinland Low Blue Light Certification, CU
3-year warranty
Display Type
Diagonal Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
220 cd/m²
Contrast Ratio
700:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Backlight Technology
LED backlight
Controls & Adjustments
Brightness
ASUS QuickFit Virtual Scale, ASUS GamePlus, Slim Design, Blue Light Filter technology
Black, silver
800 g
USB-C
Flicker-free technology
Carrying case with display stand
1 x DisplayPort / USB-C cable
7 Watt
Apple MacOS, Windows 10
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus MB169C+ 15.6 Bundle deal on Asus MB169C+ 15.6" Full HD USB-TypeC Portable USB Monitor
£275.09
Response Time: 5ms
Speakers: None
Interfaces: USB
Brand: Asus
Price Range Ex VAT: 150 - 300
