Asus MB169B+ 15.6" LED-Lit Monitor  IPS  1920 x 1080 USB Powered
Quicklinx: BQZWWS00 Mfr#: MB169B+
None in stock
The 15.6-inch MB169B+ portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a Full HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality.
  • Sleek and ultra-portable with a Zen-inspired design
    With a slim 8 mm (0.3-inch) profile, the MB169B+ is slim and ligh companion display, ideal for a simple on-the-go dual-monitor setup and mobile presentations. A durable metallic finish with a fine pattern of concentric circles makes the MB169B+ the perfect complement to your notebook.
  • Adjusting to your needs
    The MB169B+ automatically senses its orientation and switches the display between landscape and portrait based on its position; also, featuring IPS panel ensures a better viewing angle and nearly no color shift promise. These features provide you a more user-friendly scenario.
  • Increased productivity with ASUS EzLink technology
    The MB169B+ features ASUS EzLink technology that offloads graphics processing from the PC to dedicated hardware in the monitor. As a result, a PC can drive up to five MB169B+ monitors at the same time, regardless of its own graphics capability - it just needs sufficient USB ports. EzLink also automatically restores application window positions as a MB169B+ monitor is connected and disconnected, and automatically rotates the image between landscape and portrait modes, as required.
ASUS MB169B+ - LED monitor - Full HD (1080p) - 15.6"
LED-backlit LCD monitor - 15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.179 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 (dynamic)
Response Time
25 ms
Input Connectors
USB
Black, silver
37.9 cm x 0.85 cm x 23.6 cm
800 g
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark
Display Type
Diagonal Size
15.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.179 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 (dynamic)
Response Time
25 ms
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Brightness
Slim Design, ASUS EzLink technology, auto-rotation
Black, silver
800 g
USB 3.0
Carrying case with display stand
1 x SuperSpeed USB cable
7.5 Watt
Power Consumption (Off Mode)
0 Watt
Microsoft Windows 7, Apple MacOS X 10.8.3 or later
Shipping Width
43.5 cm
Shipping Depth
5.7 cm
Shipping Height
29.7 cm
Shipping Weight
2 kg
