Asus MB168B 15.6" 1366x768 11ms USB Powered LED Monitor
TWO SCREENS ARE BETTER THAN ONE
Quicklinx: 9TQJWS00 Mfr#: MB168B
Diagonal Size: 15.6in
Max Resolution: 1366 x 768
Response Time: 11ms
Speakers: None
Interfaces: USB
£114.59 ex VAT
£137.50 inc VAT
The 15.6-inch MB168B portable USB-powered monitor needs just one USB cable for both its video signal and power to deliver up to a 1366 x 768 HD resolution. Thanks to the higher bandwidth of USB 3.0, experience fast, fluid images from your connected device that makes having an on-the-go multi-display setup a reality.
  • One cable does the job
    15.6-inch HD display with a single USB 3.0 cable for power and data transmission.
  • Sleek and ultra-portable with a Zen-inspired design
    The MB168B is the slim and light companion display, ideal for a simple on-the-go dual-monitor setup and mobile presentations. A durable metallic finish with a fine pattern of concentric circles makes the MB168B the perfect complement to your notebook.
  • Adjusting to your needs
    The M8168B can automatically senses its orientation and switches the display between landscape and portrait based on its position, while backlight brightness is also automatically adjusted based on environmental lighting - getting brighter in the light and dimmer in the dark.
ASUS MB168B - LED monitor - 15.6"
LED-backlit LCD monitor - 15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768
Brightness
200 cd/m²
Contrast Ratio
500:1 (dynamic)
Response Time
11 ms
Input Connectors
USB
Black, silver
37.9 cm x 0.8 cm x 23.6 cm
800 g
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark
Display Type
Diagonal Size
15.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768
Brightness
200 cd/m²
Contrast Ratio
500:1 (dynamic)
Response Time
11 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
ASUS AI Light
Black, silver
800 g
USB 3.0
G-sensor
ASUS Smart Case
1 x SuperSpeed USB cable
7.5 Watt
Power Consumption (Off Mode)
0 Watt
Microsoft Windows 7
Shipping Width
43.5 cm
Shipping Depth
5.7 cm
Shipping Height
29.7 cm
Shipping Weight
2 kg
Asus MB168B 15.6 Bundle deal on Asus MB168B 15.6" 1366x768 11ms USB Powered LED Monitor
£213.76
Response Time: 11ms
Speakers: None
Interfaces: USB
Brand: Asus
Price Range Ex VAT: 100 - 150
