Asus MAXIMUS X FORMULA Intel Z370 S1151 DDR4 USB3.1 ATX
Quicklinx: DB2FWS00 Mfr#: ROG MAXIMUS X FORMULA
  • IEEE 802.11n
Drawing from a heritage that spans more than a decade, this incarnation of the MAXIMUS series features all the enhancements that enthusiasts crave. These motherboards bring the octane to your build.
  • Aura sync
    ASUS Aura offers full RGB lighting control with a variety of functional presets for the built-in RGB LEDs as well as strips connected to the onboard RGB headers.
  • Better cooling
    Equipped with a stylish, angular M.2 heatsink, your SSD keeps cool. By efficiently dissipating heat away from the M.2 area, ROG MAXIMUS minimizes the possibility of the performance-sapping throttling that can happen when drives become too warm.
  • Overclocking performance
    ASUS OptiMem preserves memory signal integrity by routing memory traces to the optimal PCB layer, and the T-topology layout ensures time-aligned signaling by balancing trace lengths between memory slots. These enhancements lead to more headroom for overclocking and improved stability.
  • Pre-mounted I/O shield
    ROG's pre-mounted I/O shield offers increased protection against electrostatic discharges and is pre-fitted to make it even easier to install the motherboard. Its sleek design makes it look as good as it performs.
ASUS ROG MAXIMUS X FORMULA - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 + (1 x USB 3.1 Gen 2 + 2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
SupremeFX (S1220)
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16, x8/x8, x8/x4+x4 modes) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x HDMI , 1 x DisplayPort , 4 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 4 x USB 2.0
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB 3.1 Gen 2 - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Q-Code, SupremeFX Shielding technology, AMD 3-way CrossFireX technology support, Dual Intelligent Processors 5, LANGuard, KeyBot II, GameFirst IV, ROG SSD Secure Erase, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS SafeSlot, Intel Optane Memory Ready, Sonic Radar III, Sonic Studio III, CrossChill EK II, ASUS LiveDash, ASUS PRO Clock II Technology
ASUS 2T2R Wi-Fi moving aerials, 1 x M.2 screw, ROG coasters, CPU installation tool, M.2 bracket, 2 RGB (RGBW) LED strip extension cables, ROG big sticker
6 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ROG CPU-Z, ASUS AI Suite III, ROG RAMDisk, ASUS Turbo App, Overwolf, ASUS EZ Flash 3, ROG Aura, ROG GameFirst IV, ASUS ROG RAMCache II, ROG CloneDrive
Plug and Play
30.5 cm
24.4 cm
