Maximus VIII Formula has been pumped up and packed to the brim with enhancements, so competitors are warned, gamers get set and enthusiasts prepare to push your limits - ROG is ready to accept all challenges! ROG teamed up with the cooling masters at EK Water Blocks to create CrossChill EK, an extreme-performance cooling block with a copper channel that's hungry for either air or liquid. It is used high-precision laser-engraving technology to carve beautifully intricate patterns across the ROG Armor that enrobes Maximus VIII Formula, allowing the radiant RGB light of 28 integrated LEDs to shine through and illuminate key parts of the board - including the MOSFET heatsink cover, PCIe area and the striking ROG logo on the PCH cover!
Totally cooled - CrossChill EK
ROG teamed up with the cooling masters at EK Water Blocks to create CrossChill EK, an extreme-performance cooling block with a copper channel that's hungry for either air or liquid. CrossChill EK is the cool choice for custom-chilled builds enabling quieter rigs that run great on air - and even better with water. CrossChill EK is a quick fit for your existing setup and, when you chill with liquid, you'll shrink MOSFET temperatures by up to 23°C! -
Amazing gaming lighting
Build with Maximus VIII Formula and you'll build... bright! With a built-in Aura RGB-strip header and easy lighting controls, it's never been easier to light up your rig - and your LAN parties! -
RGB-strip header & lighting control
It is used high-precision laser-engraving technology to carve beautifully intricate patterns across the ROG Armor that enrobes Maximus VIII Formula, allowing the radiant RGB light of 28 integrated LEDs to shine through and illuminate key parts of the board - including the MOSFET heatsink cover, PCIe area and the striking ROG logo on the PCH cover! Forget the faff of external RGB controllers! With ROG's Aura RGB-strip header, it's quick and easy to cast brilliant colors across your rig and room. Customize static, strobing and pulsating effects, or have the colors change in time with music or indicate CPU temperature. -
Incredible gaming audio
You'd never win with your eyes closed, so open your ears up to an amazing audio for the battlefield! ROG's awesome audio expertise is the result of extensive R&D, and SupremeFX is the crystal-clear result - onboard sound as superior as your gaming rep! -
Audio from SupremeFX 2015
Maximus VIII Formula's onboard audio isn't just good - it's as good as you can get! You benefit from great gaming-audio inputs and outputs, with special shielded designs, and a collection of carefully selected professional-grade audio components, including a digital-to-analog converter (DAC) with Hyperstream technology, ultra-low-jitter clock, Nichicon capacitors, and Sonic SenseAmp that automatically detects and optimizes any headset for pure sound quality. SupremeFX 2015 also features intuitive Sonic Studio II, so you'll apply and enjoy different audio effects for perfect entertainment - plus Perfect Voice noise-cancellation technology for team conversations with total clarity! -
Get performance, efficiency, digital power, fan control
You don't need to be an expert to max out gaming performance on your Maximus VIII Formula build's gaming performance - because 5-Way Optimization sorts all the complex settings with a click, for instant, highly-controllable performance boosts! This amazing technology dynamically optimizes essential aspects of your system based on real-time use, so you get superb CPU performance, everyday energy savings, ultra-stable digital power, cool and quiet fans and even networking and audio settings that are tailored for the apps that you are using. In short, 5-Way Optimization ensures that your PC is perfect for gaming, entertainment, productivity or just about anything else! -
Speed your game loads
ROG's uniquely-intelligent technology effectively caches an entire storage device so that favorite games and apps launch at breakneck speeds, getting to work the moment it's activated. -
Advanced gaming connectivity
Maximus VIII Formula accelerates every connection, with the fast 802.11ac MU-MIMO Wi-Fi, the reversible USB 3.1 Type-C and the U.2 socket for lighting speed NVM Express devices - kicking every game into top gear.
- ASUS ROG MAXIMUS VIII FORMULA - motherboard - ATX - LGA1151 Socket - Z170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x SATA-600, 2 x SATA Express port, 1 x M.2, 1 x U.2 port
- USB / FireWire Ports
- 1 x USB-C + 1 x USB 3.1 + 6 x USB 3.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 512 MB
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z170
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3500 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 512 MB
Audio
- Audio Codec
- SupremeFX 2015
- DTS Connect, High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x4 mode) , 3 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin Serial ATA, 1 x M.2, 2 x SATA Express port, 1 x U.2 port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
- RAID Features
- Intel Rapid Storage Technology
- 1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 , 1 x USB-C , 6 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, Q-Code, SupremeFX Shielding technology, AMD 3-way CrossFireX technology support, ASUS Wi-Fi GO!, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Disk Unlocker, ASUS SSD Secure Erase, Preboot eXecution Environment (PXE), Clear CMOS Button, ROG Armor, NexFET, ASUS Fan Xpert 3, Dual Intelligent Processors 5, LANGuard, Sonic Radar II, Sonic SenseAmp, TrueVolt USB, USB 3.1 Boost, ASUS PRO Clock Technology, Water Cooling Ready Heatsink Design, Sonic Studio II, KeyBot II, Lighting Control, GameFirst IV, CrossChill EK
- Included Accessories
- ROG Door Hanger, cable labels, ASUS 2T2R Wi-Fi moving aerials, 1 x M.2 screw, I/O back cover, ROG fan stickers
- Cables Included
- 8 x Serial ATA cable , 1 x 3-way SLI bridge , 1 x SLI bridge
- Software Included
- Drivers & Utilities, Kaspersky Anti-Virus, ASUS AI Charger+, ROG CPU-Z, ROG GameFirst Utility, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ASUS Turbo App, Mobo Connect, PC Cleaner, Media Streamer, HyStream, ASUS RAMCache, Overwolf, ROG Aura
- Plug and Play
- 30.5 cm
- 24.4 cm
