This motherboard supports powerful processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel memory support and accelerates data transfer rate via HyperTransport 3.0 based system bus. The ASUS EPU, the power-saving engine, has been upgraded to a 4-engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real time. The EPU automatically provides the appropriate power usage for the CPU, VGA card, hard drives and CPU cooler fan - helping save power and money.
Anti-surge protection
Anti-surge protection design detects overvoltage conditions and prevents voltage surges from spreading in real time. It also actively cuts off the overvoltage supply to protect the system. -
Low EMI
A special low-radiation design shields you from harmful electromagnetic exposure by eliminating radiation. -
ESD
Protect your computer with ESD guards. Electrostatic discharge (ESD) conditions can happen while plugging or unplugging any USB peripherals-causing damage to the computer. ASUS ESD guards clamp the ESD voltage and shunt the majority of the ESD current away for a more reliable computing environment. -
USB 3.0 support
Experience ultra-fast data transfer with USB 3.0 - the advanced connectivity standard. Built to connect easily with components and peripherals, USB 3.0 transfers data faster and is also backward compatible with USB 2.0 components. -
Fan X-pert
ASUS Fan Xpert intelligently allows you to adjust the CPU and chassis fan speeds according to different ambient temperatures, caused by different climate conditions in different geographic regions and your PC's loading. The built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment.
- ASUS M5A78L-M PLUS/USB3 - motherboard - micro ATX - Socket AM3+ - AMD 760G
- Product Type
- Motherboard - micro ATX
- Chipset Type
- AMD 760G / AMD SB710
- Processor Socket
- 1 x Socket AM3+
- Compatible Processors
- Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX (Maximum TDP 125 Watt)
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
- Storage Ports
- 6 x SATA-300 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Graphics
- ATI Radeon HD 3000
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Processor Socket
- Socket AM3+
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1333 MHz, 1066 MHz, 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 1600 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Graphics
- Graphics Controller
- 1 GB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
- Storage Interfaces
- SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 2 x USB 3.0 , 1 x DVI , 1 x HDMI
- Internal Interfaces
- 4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support
- Hardware Features
- AMD Cool 'n' Quiet Technology, ASUS Anti-Surge Protection, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS EPU-4 Engine, Core Unlocker, AMD Hybrid CrossFireX technology support, Low EMI Solution
- Included Accessories
- I/O back plate
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger, ASUS Update, Antivirus (OEM version)
- Plug and Play, ACPI 2.0a, ErP Ready
- 24.4 cm
- 22.9 cm
