Your basket is empty
Asus M5A78L-M PLUS/USB3 AM3+ 760G DDR3 USB3.0 mATX
Quicklinx: CBVXWS00 Mfr#: M5A78L-M PLUS/USB3
Processor Socket: Socket AM3+
Chipset: AMD 760G
Graphics: Graphics adapter
Form Factor: Micro ATX
Memory Support: DDR3 SDRAM
£53.19 ex VAT
£63.82 inc VAT
This motherboard supports powerful processors with unique L3 cache and delivers better overclocking capabilities with less power consumption. It features dual-channel memory support and accelerates data transfer rate via HyperTransport 3.0 based system bus. The ASUS EPU, the power-saving engine, has been upgraded to a 4-engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real time. The EPU automatically provides the appropriate power usage for the CPU, VGA card, hard drives and CPU cooler fan - helping save power and money.
ASUS M5A78L-M PLUS/USB3 - motherboard - micro ATX - Socket AM3+ - AMD 760G
Motherboard - micro ATX
Chipset Type
AMD 760G / AMD SB710
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Phenom II X3, Athlon II X2, Phenom II X2, Athlon II X4, Athlon II X3, Phenom II X4, Phenom II X6, FX (Maximum TDP 125 Watt)
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, ECC, unbuffered
Storage Ports
6 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Graphics
ATI Radeon HD 3000
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz, 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 1600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
ATI Radeon HD 3000
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / JBOD
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 2 x USB 3.0 , 1 x DVI , 1 x HDMI
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support
Hardware Features
AMD Cool 'n' Quiet Technology, ASUS Anti-Surge Protection, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), ASUS Fan Xpert, ASUS EPU-4 Engine, Core Unlocker, AMD Hybrid CrossFireX technology support, Low EMI Solution
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Charger, ASUS Update, Antivirus (OEM version)
Plug and Play, ACPI 2.0a, ErP Ready
24.4 cm
22.9 cm
Asus M5A78L-M PLUS/USB3 AM3+ 760G DDR3 USB3.0 mATX Bundle deal on Asus M5A78L-M PLUS/USB3 AM3+ 760G DDR3 USB3.0 mATX
£66.68
saving £7.27
Chipset: AMD 760G
Brand: Asus
Price Range Ex VAT: 50 - 100
