Stylish and space-saving design
VivoPC K20 is a stylish and elegant PC for the modern home. From its brushed metal finished front panel to its elegant gold power bar, the well-crafted VivoPC K20 makes a wonderful addition to any room of your house. The ultimate chassis takes up very little space, allowing you to place it under the table in your study or beside your TV. -
Smart multimedia performance
VivoPC K20 is powered by unrivaled processor to give you significantly faster and more efficient multitasking performance over previous iterations. DDR4 memory provides speeds twice faster than DDR3. VivoPC K20 enhances your daily computing experience, making online shopping, writing blogs, conducting presentations, or watching movies all the more enjoyable. -
Expansive audio, tuned by experts
A mixture of hardware, software, and tuning, ASUS SonicMaster was developed with the clear goal of giving you the best PC audio. A professional codec ensures precise sound performance; while an optimized amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass. Additional signal processing helps fine tune the hardware, filtering noise and improving clarity so you can enjoy unrivaled audio on your ASUS VivoPC K20. -
Environment friendly ultra-quiet
VivoPC K20 isn't just superb in performance, it's extremely quiet as well. You won't be disturbed when you leave VivoPC K20 on overnight, as it runs whisper-quiet below 25 dB at idle - more quiet than a typical library. No more disturbance when your studying or busy on work. -
SuperSpeed USB 3.1 transmission
VivoPC K20 features SuperSpeed USB 3.1 transfering data up to 20 times faster than USB 2.0, and 2 times faster than USB 3.0. Besides, it also comes with all the connectivity options you need. HDMI output ports lets you hook your VivoPC K20 up to an HDTV to supersize your entertainment. SATA 6 Gbit/s ports offer blisteringly fast data transfer speeds, letting you save large files or quickly load games. -
Ultra-fast connectivity
With wireless transfer rates up to 433 Mbit/s with compatible routers, 802.11ac Wi-Fi is around 8 times faster than 802.11g and around 3 times faster than 802.11n, making the VivoPC K20 Series capable of streaming 4K/Ultra HD video without the inconvenience of network cables.
- ASUS VivoPC K20CD UK042T - mini PC - Core i3 6100 3.7 GHz - 4 GB - HDD 1 TB
- Personal computer - mini PC
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Card Reader
- 6 in 1
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- 7.1 channel surround
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5
- OS Provided
- Windows 10 Home 64-bit Edition
- Silver
- 9.6 cm x 27.9 cm x 38.1 cm
- 5.5 kg
- Limited warranty - 1 year
- Personal computer
- Product Form Factor
- Mini PC
- Silver
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H110 Express
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
- Dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 2
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Card Reader
- 6 in 1 card reader
- Supported Flash Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Connectivity
- Wireless
Mouse
- Connectivity
- Wireless
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 1 external 5.25"
- Slots
- 1 (total) / 0 (free) x CPU , 2 SO-DIMM 260-pin , 1 (total) / 1 (free) x PCIe x16 , 1 Mini PCIe
- 3 x USB 3.0 (2 in front) , 2 x USB 3.1 , 1 x HDMI output , 1 x VGA output , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- VCCI, C-Tick, BSMI, CB, CCC, FCC, ETL
- Power adapter
- Power Provided
- 120 Watt
Operating System / Software
- OS Provided
- 9.6 cm
- 27.9 cm
- 38.1 cm
- 5.5 kg
