Product
Asus K20CD-UK039T Intel Core i5-6400 8GB 2TB Windows 10
Quicklinx: C7KHWS00 Mfr#: K20CD-UK039T
  • Core i5
Marketing description is not available.
  • Stylish and space-saving design
    The VivoPC K20CD is a stylish and elegant PC for your home. From its brushed metal finished front panel to its elegant power bar, the well-crafted VivoPC K20CD makes a wonderful addition to any room of your house. The chassis takes up very little space, allowing you to place it under the table in your study or beside your TV.
  • Smart multimedia performance
    The VivoPC K20CD is powered an incredible processor to give you significantly faster and more efficient multitasking performance. The VivoPC K20CD enhances your daily computing experience, making online shopping, writing blogs, conducting presentations, or watching movies very enjoyable.
  • Expansive audio
    A professional codec ensures precise sound performance; while an optimized amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass. Additional signal processing helps fine tune the hardware, filtering noise and improving clarity so you can enjoy amazing audio.
  • Environmentally friendly and ultra-quiet
    The VivoPC K20CD isn't just superb in performance, it's extremely quiet as well. You won't be disturbed when you leave it on overnight, as it runs whisper-quiet. No more disturbance when you're studying or busy on work.
  • USB 3.1 transmission
    The VivoPC K20CD features USB 3.1 transfering data for incredible speed. Besides, it also features all the connectivity options you need. HDMI output port lets you hook your VivoPC K20CD up to an HDTV to supersize your entertainment.
ASUS VivoPC K20CD UK039T - mini PC - Core i5 6400 2.7 GHz - 8 GB - 2 TB
Personal computer - mini PC
1 x Intel Core i5 (6th Gen) 6400 / 2.7 GHz (3.3 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 2 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
6 in 1
Graphics Controller
Intel HD Graphics 530
Audio Output
7.1 channel surround
GigE, Bluetooth, 802.11ac
OS Provided
Windows 10 Home 64-bit Edition
9.6 cm x 27.9 cm x 38.1 cm
5.5 kg
Limited warranty - 1 year
Personal computer
Product Form Factor
Mini PC
Silver
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H110 Express
RAM
Installed Size
8 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Dual channel memory architecture
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Channel Qty
2
Optical Storage
DVD SuperMulti
Card Reader
6 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Wireless
Mouse
Wireless
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11ac
Bays
1 external 5.25"
Slots
1 (total) / 0 (free) x CPU , 2 SO-DIMM 260-pin , 1 (total) / 1 (free) x PCIe x16 , 1 Mini PCIe
3 x USB 3.0 (2 in front) , 2 x USB 3.1 , 1 x HDMI , 1 x VGA output , 1 x LAN (Gigabit Ethernet) , 1 x headphones - mini-jack (1 in front) , 2 x microphone - mini-jack (1 front, 1 rear) , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
VCCI, C-Tick, BSMI, CB, CCC, FCC, ETL
Power adapter
Power Provided
120 Watt
Operating System / Software
OS Provided
9.6 cm
27.9 cm
38.1 cm
5.5 kg
