This supreme motherboard comes with 5X Protection II for dependable stability, DDR4 support and lightning-fast USB 3.1. Advanced 5X Protection II employs high-quality components, excellent circuit design, and high standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build - the result of decades of engineering experience from the famous motherboard brand.
Advanced hardware safeguards
Advanced 5X Protection II employs high-quality components, excellent circuit design, and high standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build - the result of decades of engineering experience from the famous motherboard brand. -
LANGuard
ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges. -
Overvoltage protection
An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies. -
DRAM overcurrent protection
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected devices. -
DIGI+ VRM
DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability. -
Stainless-steel back I/O
Corrosion-resistant stainless steel back I/O panels bonded with chromium oxide have a much longer lifespan than ordinary panels. -
ESD guards
Electrostatic discharge (ESD) can happen suddenly, and its damaging effects are easily underestimated. ASUS ESD guards employ an active protective circuit design to guard your system against electrostatic interference and damage, providing greater component longevity. -
EZ tuning wizard - OC and RAID
Select your hardware and apply different scenarios to tune system performance, or streamline your RAID configuration for faster data retrieval and backups. -
SATA Express
SATA Express is an advanced connectivity standard - and ensures that you and your system won't get left behind. -
M.2
With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports up to 32 Gbit/s data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible. -
10 Gbit/s USB 3.1 onboard
With USB 3.1 Type-A port, you'll experience data transfer speeds of up to 10 Gbit/s - or twice as fast USB 3.0. USB 3.1 is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further. -
Instant front-panel USB 3.0 experience
USB 3.0 is right where you need it - four super-speed ports on the front panel. Experience data-transfer speeds up to much faster than USB 2.0 with instant Plug-and-Play connectivity, so no more back-breaking contortions in the hunt for hard-to-reach rear ports. -
USB Type-C for convenient connectivity
USB Type-C (USB-C) delivers future device compatibility and high-speed USB connectivity from a slim, reversible port. -
Gear up and win the battlefield
Beautiful LED-illuminated trace paths brighten your build and highlight noise-isolated, precision-shielded, interference-eliminated onboard audio. -
LED-illuminated design
Brighten up your build with the gorgeous illuminated audio trace path. -
Audio enjoyment
Audio shielding ensures precision analog / digital separation and greatly reduced multi-lateral interference. Separate layers for left and right tracks ensure both channels deliver consistent, equal quality. Premium audio capacitors provide warm, natural, and immersive sound with exceptional clarity and fidelity. -
Safe motherboard mounting
Fitting your ASUS motherboard is very safe. The comprehensive component-free 'safe zones' around every case-mounting hole minimizes the risk of damage and short circuits caused by contact - so you'll assemble your PC with total confidence. -
Q-Slot
The large winged clip is easy to reach and easy to operate. Just press the Q-Slot clip lightly, and graphics card just pop out. Installing or removing even very big graphics cards is no sweat. -
Q-DIMM
Even if you work with a smaller case, just push down on the one-sided clip and push or pull RAM modules in or out - couldn't be simpler. -
Advanced fan controls
With onboard thermal sensors and hardware-level 4-pin / 3-pin PWM / DC mode detection, Fan Xpert 3 makes sure every fan achieves optimal balance of cooling performance and low noise.
- ASUS H170-PRO/USB 3.1 - motherboard - ATX - LGA1151 Socket - Intel H170
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel H170
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 2 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel H170
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCI
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x DisplayPort , 2 x USB 2.0 , 2 x USB 3.1 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x USB-C
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, AMD Quad CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Intel Small Business Advantage support, Low EMI Solution, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, USB 3.1 Boost, ASUS Overvoltage Protection, ASUS 5X Protection II
- Included Accessories
- I/O back plate, 1 x M.2 screw
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, ASUS EZ Flash 3
- Plug and Play
- 30.5 cm
- 22.4 cm
