Asus H170-PRO/USB 3.1 Intel H170 S1151 DDR4 M.2 USB TypeC ATX
Quicklinx: BTSLWS00 Mfr#: H170-PRO/USB 3.1
This supreme motherboard comes with 5X Protection II for dependable stability, DDR4 support and lightning-fast USB 3.1. Advanced 5X Protection II employs high-quality components, excellent circuit design, and high standards to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build - the result of decades of engineering experience from the famous motherboard brand.
  • Advanced hardware safeguards
  • LANGuard
    ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
  • Overvoltage protection
    An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
  • DRAM overcurrent protection
    Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected devices.
  • DIGI+ VRM
    DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability.
  • Stainless-steel back I/O
    Corrosion-resistant stainless steel back I/O panels bonded with chromium oxide have a much longer lifespan than ordinary panels.
  • ESD guards
    Electrostatic discharge (ESD) can happen suddenly, and its damaging effects are easily underestimated. ASUS ESD guards employ an active protective circuit design to guard your system against electrostatic interference and damage, providing greater component longevity.
  • EZ tuning wizard - OC and RAID
    Select your hardware and apply different scenarios to tune system performance, or streamline your RAID configuration for faster data retrieval and backups.
  • SATA Express
    SATA Express is an advanced connectivity standard - and ensures that you and your system won't get left behind.
  • M.2
    With x4 PCI Express 3.0/2.0 bandwidth, M.2 supports up to 32 Gbit/s data-transfer speeds. It is the perfect choice for an operating system or application drive, making your whole PC or professional apps work as fast as possible.
  • 10 Gbit/s USB 3.1 onboard
    With USB 3.1 Type-A port, you'll experience data transfer speeds of up to 10 Gbit/s - or twice as fast USB 3.0. USB 3.1 is completely backward-compatible with your existing USB devices, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 Boost technology automatically accelerates USB 3.1 performance even further.
  • Instant front-panel USB 3.0 experience
    USB 3.0 is right where you need it - four super-speed ports on the front panel. Experience data-transfer speeds up to much faster than USB 2.0 with instant Plug-and-Play connectivity, so no more back-breaking contortions in the hunt for hard-to-reach rear ports.
  • USB Type-C for convenient connectivity
    USB Type-C (USB-C) delivers future device compatibility and high-speed USB connectivity from a slim, reversible port.
  • Gear up and win the battlefield
    Beautiful LED-illuminated trace paths brighten your build and highlight noise-isolated, precision-shielded, interference-eliminated onboard audio.
  • LED-illuminated design
    Brighten up your build with the gorgeous illuminated audio trace path.
  • Audio enjoyment
    Audio shielding ensures precision analog / digital separation and greatly reduced multi-lateral interference. Separate layers for left and right tracks ensure both channels deliver consistent, equal quality. Premium audio capacitors provide warm, natural, and immersive sound with exceptional clarity and fidelity.
  • Safe motherboard mounting
    Fitting your ASUS motherboard is very safe. The comprehensive component-free 'safe zones' around every case-mounting hole minimizes the risk of damage and short circuits caused by contact - so you'll assemble your PC with total confidence.
  • Q-Slot
    The large winged clip is easy to reach and easy to operate. Just press the Q-Slot clip lightly, and graphics card just pop out. Installing or removing even very big graphics cards is no sweat.
  • Q-DIMM
    Even if you work with a smaller case, just push down on the one-sided clip and push or pull RAM modules in or out - couldn't be simpler.
  • Advanced fan controls
    With onboard thermal sensors and hardware-level 4-pin / 3-pin PWM / DC mode detection, Fan Xpert 3 makes sure every fan achieves optimal balance of cooling performance and low noise.
ASUS H170-PRO/USB 3.1 - motherboard - ATX - LGA1151 Socket - Intel H170
Motherboard - ATX
Chipset Type
Intel H170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
1 x USB-C + 2 x USB 3.1 + 2 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1 , 1 x PCIe 3.0 x16 (x4 mode) , 2 x PCI
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 1 x DisplayPort , 2 x USB 2.0 , 2 x USB 3.1 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x USB-C
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x audio - header , 1 x SPDIF out - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Anti-Surge Protection, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Fanless Design Heatsink, AMD Quad CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, Intel Small Business Advantage support, Low EMI Solution, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, LANGuard, USB 3.1 Boost, ASUS Overvoltage Protection, ASUS 5X Protection II
I/O back plate, 1 x M.2 screw
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, ASUS EZ Flash 3
Plug and Play
30.5 cm
22.4 cm
