Asus H110T Intel H110 S1151 DDR4 M.2 USB3.0 ThinMini-ITX
Quicklinx: C32FWS00 Mfr#: H110T
Processor Socket: LGA1151 Socket
Chipset: Intel H110 Express
Graphics: Graphics adapter (CPU required)
Form Factor: Thin mini ITX
Memory Support: DDR4 SDRAM
19 in stock
£67.20 ex VAT
£80.64 inc VAT
5X Protection II employs fine components and excellent circuit design to guarantee quality and long-term durability of your motherboard with all-round protection. For you, that means exceptional protection and stability for your build.
  • Advanced hardware safeguards
  • Overvoltage protection
    Advanced circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies.
  • Optimized cooling
    Fan Xpert ensures every fan achieves great balance of cooling performance and low noise. Fan Xpert even includes auto-tuning mode to scan and detect all fan characteristics for easy customization.
ASUS H110T - motherboard - Thin mini ITX - LGA1151 Socket - H110
Motherboard - Thin mini ITX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
2 SO-DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
2 x SATA-600, 1 x M.2
USB / FireWire Ports
USB 3.0 4 x USB 3.0 + (5 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
2 x Gigabit Ethernet
3-year warranty
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Intel I219V / Realtek RTL8111H
Network Interfaces
Expansion Slots
1 x CPU , 2 x SO-DIMM 260-pin , 1 x M.2 socket
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 2 x 7pin SATA, 1 x M.2
4 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 2 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x HDMI
Internal Interfaces
5 x USB 2.0 - header , 1 x audio - header , 1 x LVDS - header , 1 x serial - header
Power Connectors
DC-in power connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Conductive Polymer Capacitors, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, LANGuard, ASUS 5X Protection II, Intel Small Business Basics support, overvoltage protection
I/O back plate, 2 x M.2 screws, Thin mini ITX I/O back plate
2 x Serial ATA cable , 1 x Serial ATA power cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, PC Cleaner, Media Streamer, ASUS EZ Flash 3
Plug and Play, ACPI 5.0
17 cm
17 cm
Limited warranty - 3 years
C32F C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.97
C32F C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.08
C32F C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
C32F C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.69
C32F C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.45
C32F C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.06
C32F C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.14
Brand: Asus
Price Range Ex VAT: 50 - 100
