The 5X Protection II employs fine components, excellent circuit design, and exacting standards to guarantee quality and long-term durability of your motherboard with all-round protection. ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges.
Advanced hardware safeguards
The 5X Protection II employs fine components, excellent circuit design, and exacting standards to guarantee quality and long-term durability of your motherboard with all-round protection. -
LANGuard
ASUS LANGuard is hardware-level networking protection that employs signal-coupling technology and premium anti-EMI surface-mounted capacitors ensuring a more reliable connection and better throughput, plus electrostatically-guarded and surge-protected components for greater tolerance to static electricity and improved protection against surges. -
Overvoltage protection
An exclusive circuit design with built-in voltage regulators to protect your chipset, connectivity ports, and audio codecs from damage caused by unexpected high-level voltages from unstable or inferior power supplies. -
Short-circuit damage prevention
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected devices. -
Precision control for stable power
ASUS-exclusive DIGI+ VRM intelligently delivers power to the processor based on real-time demands, reducing energy waste and improving system stability. -
3X corrosion-resistance for greater durability
Corrosion-resistant stainless=steel back I/O panels bonded with chromium oxide have a lifespan that's three times longer than ordinary panels. -
Dedicated CPU and case fan controls
Exclusive Fan Xpert ensures every fan achieves great balance of cooling performance and low noise - and with the 100 series boards and their hardware-level 4-pin/3-pin PWM/DC mode for case fans, a simple BIOS adjustment lets you run your case fan in PWM/DC. Fan Xpert even includes auto-tuning mode to scan and detect all fan characteristics for single-click customization!
- ASUS H110S1 - motherboard - mini STX - LGA1151 Socket - H110
- Product Type
- Motherboard - mini STX
- Chipset Type
- Intel H110 Express
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 32 GB
- RAM Supported
- 2 SO-DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C + 2 x USB 3.0 + 1 x USB 2.0
- Max Allocated RAM Size
- 1024 MB
- Audio
- HD Audio (4-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Intel Extreme Memory Profiles (XMP)
Graphics
- 1024 MB
Audio
- Audio Codec
- Realtek ALC3236
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 2 x SO-DIMM 260-pin , 1 x M.2 socket
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 2 x 7pin SATA, 1 x M.2
- 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 2 x HDMI , 1 x USB 2.0 , 1 x USB-C , 1 x microphone , 1 x audio line-out/microphone - mini-jack
- Internal Interfaces
- 1 x LVDS - header , 1 x serial - header
- Power Connectors
- DC-in power connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS EZ DIY, CrashFree BIOS 3, audio jack detect technology, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Conductive Polymer Capacitors, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, LANGuard, ASUS Overvoltage Protection, ASUS 5X Protection II, Intel Small Business Basics support
- Included Accessories
- I/O back plate, 2 x M.2 screws
- Cables Included
- 2 x Serial ATA cable , 1 x Serial ATA power cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Media Streamer, ASUS EZ Flash 3
- Plug and Play, ACPI 5.0
- 14.7 cm
- 14 cm
